Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Linksys WRT54G zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Linksys WRT54G Teardown, Get your Linksys: Schritt 1, Bild 1 von 2 Linksys WRT54G Teardown, Get your Linksys: Schritt 1, Bild 2 von 2
    • The Linksys WRT54G series is a series of Wi-Fi gateways manufactured by Linksys, a subsidiary of Cisco Systems.
  2. Linksys WRT54G Teardown, Antenna Removal: Schritt 2, Bild 1 von 2 Linksys WRT54G Teardown, Antenna Removal: Schritt 2, Bild 2 von 2
    • Let's begin with the teardown! First, unscrew the antennas from the back of the router and set them aside.
  3. Linksys WRT54G Teardown, Front Panel Removal: Schritt 3, Bild 1 von 3 Linksys WRT54G Teardown, Front Panel Removal: Schritt 3, Bild 2 von 3 Linksys WRT54G Teardown, Front Panel Removal: Schritt 3, Bild 3 von 3
    • Lets get into the internals! First, flip the unit over and insert a small flat-head screwdriver in between the warranty sticker and the front panel and gently pry it open.
    • Beware! It may take some effort to pry the panel off. Also, be careful not to damage the motherboard, like I did.
    • This will certainly void your warranty from 2002, in case you wanted to know.
  4. Linksys WRT54G Teardown, Remove Top Panel: Schritt 4, Bild 1 von 3 Linksys WRT54G Teardown, Remove Top Panel: Schritt 4, Bild 2 von 3 Linksys WRT54G Teardown, Remove Top Panel: Schritt 4, Bild 3 von 3
    • Now, slide the top plastic panel off and put it aside you now have a clear view of the motherboard.
    • Intel TE28F320 Flash Memory
    • Broadcom BCM4712KPB (I think it’s a modem chip)
    • Admtek ADM6996L Ethernet Controller
    • Activity LEDs
    • Issi 42S16400-6T Random Access Memory (unsure how much)
    • An assortment of other chips I couldn't find.
  5. Linksys WRT54G Teardown, Remove Motherboard: Schritt 5, Bild 1 von 3 Linksys WRT54G Teardown, Remove Motherboard: Schritt 5, Bild 2 von 3 Linksys WRT54G Teardown, Remove Motherboard: Schritt 5, Bild 3 von 3
    • Time to remove the motherboard! Unscrew the single Phillips screw, slide the motherboard and then lift it out.
    • Single Phillips screw
    • Plastic slips holding the motherboard in place.
  6. Linksys WRT54G Teardown, Done!: Schritt 6, Bild 1 von 1
    • You're done! Thanks for sticking with me for my first teardown!
    • If you want to reassemble this, just do this guide in reverse order! (assuming you didn't break it like I did)
Reed Crosby
4.368 Reputation
1 Anleitung geschrieben
Kid fixers Mitglied von Kid fixers
Community
156 Mitglieder
292 Anleitungen geschrieben
2 Kommentare
Happened to get one of these from goodwill recently and wanted to take it apart to take a look. This was really helpful for doing that, deeply appreciate these teardown posts.
Chris Caldwell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 7,462
