Einleitung
This is a step by step teardown of a Logitech webcam which is helpful if you are trying to build a stereo camera and remove the infrared filter or even simply adjust the focus.
Was du brauchst
Remove Camera from the box
Pull to remove the base
Pry off the button mounted on the side
Green arrow indicates the location of screw hole
Use a #0 Phillips head screwdriver to remove the screw
Remove the screw indicated by the green arrows
The lens can be screwed and unscrewed to adjust focus. However it is glued in place and should be reglued after adjustment
The screws indicated by the blue arrows hold the lens module in place
The infrared filter is accessible from the back of the lens module. It is the shiny piece of reddish glass.
Attached to the white plastic is the privacy shade position sensor.
The ccd sensor appears to be 1/3.2" Type sensor with 4:3 aspect ratio. With is 4.536mm x 3.416mm. Focal length is currently undetermined.
The lens is threaded M10x0.5, and testing seems to indicate that the sensor is a CCD with global shutter.
