Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
  1. M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: Schritt 1, Bild 1 von 2 M8s OTT TV BOX  Teardown, M8s OTT TV BOX  Teardown: Schritt 1, Bild 2 von 2
    • Remove 4 circle pads to access the 4 screws. Using a Philips head screwdriver, remove all 4.
  2. M8s OTT TV BOX  Teardown, Remove the bottom: Schritt 2, Bild 1 von 3 M8s OTT TV BOX  Teardown, Remove the bottom: Schritt 2, Bild 2 von 3 M8s OTT TV BOX  Teardown, Remove the bottom: Schritt 2, Bild 3 von 3
    • Remove the 4 circular pads, then using a Phillips screwdriver. Remove the 4 screws.
    • Using the metal spudger in the slits parallel to the Seal you will be able to separate the two piece's.
    • The piece should come off easily.
  3. M8s OTT TV BOX  Teardown: Schritt 3, Bild 1 von 3 M8s OTT TV BOX  Teardown: Schritt 3, Bild 2 von 3 M8s OTT TV BOX  Teardown: Schritt 3, Bild 3 von 3
    • With a firm grip at the base of the cable pull up and away from board.
    • Locate the 4 screws, then using the Phillips screwdriver remove them.
    • Before the board can be removed, be sure to use your tweezers to untape the antenna from the housing.
    • The board should come out with ease.
  4. M8s OTT TV BOX  Teardown, Remove the LED board: Schritt 4, Bild 1 von 1
    • Using your Phillips head screwdriver remove the 2 screws that hold the unit to the housing
  5. M8s OTT TV BOX  Teardown, Remove the steel heat plate: Schritt 5, Bild 1 von 2 M8s OTT TV BOX  Teardown, Remove the steel heat plate: Schritt 5, Bild 2 von 2
    • With your Phillips head screwdriver, remove the 3 screws that hold it in place.
    • The device has been effectively disassembled.
    • Next I will guide you through a Detailed inspection of the main circuit board.
Austin Pollard
1.474 Reputation
3 Anleitungen geschrieben
Reno Phone Repair Mitglied von Reno Phone Repair
Business
1 Mitglied
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 2,175
