Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Mac Pro 2009-2012 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Mac Pro 2009-2012 Teardown, Open the Case: Schritt 1, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Open the Case: Schritt 1, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Open the Case: Schritt 1, Bild 3 von 3
    • To open the Mac Pro, you'll have to lift the clip on the back of the case
    • Leave the clip open during the entire disassembly!
  2. Mac Pro 2009-2012 Teardown, Remove the side panel: Schritt 2, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Remove the side panel: Schritt 2, Bild 2 von 2
    • Lift the flap to put it in the unlocked position. The panel should separate from the case without force.
  3. Mac Pro 2009-2012 Teardown, Remove the hard drives: Schritt 3, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Remove the hard drives: Schritt 3, Bild 2 von 2
    • Then to remove the hard drives, pull them towards you with a bit of force.
  4. Mac Pro 2009-2012 Teardown, Remove the DVD drives: Schritt 4, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the DVD drives: Schritt 4, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the DVD drives: Schritt 4, Bild 3 von 3
    • Simply pull the DVD drive bracket towards you, just like with the hard drives. Force it gently.
    • Unplug de power cable and the SATA cable of each DVD drive
  5. Mac Pro 2009-2012 Teardown, Remove the CPU board: Schritt 5, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU board: Schritt 5, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU board: Schritt 5, Bild 3 von 3
    • Press both latches to unlocket the bracket.
    • Then, pull it towards you.
    • You shouldn't need to apply much force.
  6. Mac Pro 2009-2012 Teardown, Disconnect the GPU: Schritt 6, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Disconnect the GPU: Schritt 6, Bild 2 von 2
    • Remove the 6 or 8 pin connector from your graphics card.
    • This step is optional, it will depend on the graphics card of your Mac Pro
  7. Mac Pro 2009-2012 Teardown, Remove the GPU ( Optional ): Schritt 7, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the GPU ( Optional ): Schritt 7, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the GPU ( Optional ): Schritt 7, Bild 3 von 3
    • On the fan bracket, there is something like a button. Press it to move the support to the left (see picture)
    • Then pull the graphics card towards you to take it out of the case
    • This step is optional depending on the GPU of your Mac Pro
  8. Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): Schritt 8, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Disconnect GPU support ( optional): Schritt 8, Bild 2 von 2
    • Disconnect the PCI-e cables from the motherboard
  9. Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: Schritt 9, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: Schritt 9, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Take out the PCI-e fan: Schritt 9, Bild 3 von 3
    • With a screwdriver, unscrew the two screws that hold the fan bracket to the board
    • Pull the fan towards you (to move it away from the case)
  10. Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: Schritt 10, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Disconnect the SATA Cables: Schritt 10, Bild 2 von 2
    • Behind the fan bracket, there are 2 SATA cables, a 4 pin mini power supply and a 4 pin fan
  11. Mac Pro 2009-2012 Teardown, Unscrew CPU support: Schritt 11, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Unscrew CPU support: Schritt 11, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Unscrew CPU support: Schritt 11, Bild 3 von 3
    • With a H2.5 screwdriver, unscrew the screws on the bottom of the bracket (photo 2)
    • With a Phillips screwdriver, unscrew the screws on the bottom of the case (photo 3)
  12. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: Schritt 12, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: Schritt 12, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: Schritt 12, Bild 3 von 3
    • Remove the clip at the top of the fan
    • Pull on the top of the fan a bit.
  13. Mac Pro 2009-2012 Teardown, Remove the CPU Fan: Schritt 13, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Remove the CPU Fan: Schritt 13, Bild 2 von 2
    • As with the top, remove the clip at the bottom and pull out the fan.
  14. Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: Schritt 14, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: Schritt 14, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Disconnect Fan and Speakers: Schritt 14, Bild 3 von 3
    • Disconnect the 2 x 4 pin fan cables and the 1 x 2 pin speaker cable
    • Do not forget this step, or else you risk damaging the connectors on the motherboard and making your fans and speaker useless!
  15. Mac Pro 2009-2012 Teardown, Remove the CPU Support: Schritt 15, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU Support: Schritt 15, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the CPU Support: Schritt 15, Bild 3 von 3
    • Pull the CPU support towards you
    • Do not use force during this step. If it does not come out easily, ensure the fans are not blocking the exit.
  16. Mac Pro 2009-2012 Teardown, Remove the expansion card connector: Schritt 16, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the expansion card connector: Schritt 16, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the expansion card connector: Schritt 16, Bild 3 von 3
    • Remove the ribbon that connects the motherboard to the expansion card (USB, Jack, Power Off etc.)
    • Warning, remove the cable carefully so as not to bend the pins which are in the connector of the motherboard!
  17. Mac Pro 2009-2012 Teardown, Remove the expansion card: Schritt 17, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the expansion card: Schritt 17, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the expansion card: Schritt 17, Bild 3 von 3
    • Unscrew the 5 screws that hold the card in place.
    • Be careful to unplug the power button of the card!
  18. Mac Pro 2009-2012 Teardown, Remove the cover: Schritt 18, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the cover: Schritt 18, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the cover: Schritt 18, Bild 3 von 3
    • Unscrew the two screws and remove the cover
  19. Mac Pro 2009-2012 Teardown, Unplug the power supply: Schritt 19, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Unplug the power supply: Schritt 19, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Unplug the power supply: Schritt 19, Bild 3 von 3
    • Push on both knobs to remove the power connector
    • Do not use force, if you are struggling ensure you are squeezing the clips adequately.
  20. Mac Pro 2009-2012 Teardown, Separate the power supply: Schritt 20, Bild 1 von 2 Mac Pro 2009-2012 Teardown, Separate the power supply: Schritt 20, Bild 2 von 2
    • Unscrew the 4 screws that hold in the power supply
  21. Mac Pro 2009-2012 Teardown, Remove the power supply: Schritt 21, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the power supply: Schritt 21, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the power supply: Schritt 21, Bild 3 von 3
    • Pull the power supply towards you.
    • Be sure to pull the connector forward and watch the cables
  22. Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: Schritt 22, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: Schritt 22, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Detach the bluetooth antenna: Schritt 22, Bild 3 von 3
    • Unclip the bluetooth antenna
  23. Mac Pro 2009-2012 Teardown, Remove the motherboard: Schritt 23, Bild 1 von 3 Mac Pro 2009-2012 Teardown, Remove the motherboard: Schritt 23, Bild 2 von 3 Mac Pro 2009-2012 Teardown, Remove the motherboard: Schritt 23, Bild 3 von 3
    • Unscrew the 10 screws holding in the motherboard
  24. Mac Pro 2009-2012 Teardown, Change the case: Schritt 24, Bild 1 von 1
    • Follow the steps in reverse for reassembly!
Ben Capehart
10.132 Reputation
18 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
57 Mitglieder
425 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 91
Letzte 30 Tage: 374
Insgesamt: 8,593
