Einleitung
Apple announced the updated MacBook Air yesterday at WWDC, so, naturally, we're taking one apart. Join us as we dig into the new 13" MacBook Air, equipped with USB 3.0 and MagSafe 2.
You like what you see? Want to see more? Follow us on Twitter to stay up-to-date with all the latest teardowns!
Was du brauchst
It's so light that it almost floats off the table…
So, what did Apple manage to pack into its ultra-slim ultrabook this time?
Intel Ivy Bridge Core i5 processor with Turbo Boost
Intel HD Graphics 4000
128 GB flash memory
4 GB 1600 MHz DDR3L RAM
USB 3.0
MagSafe 2
Even with the amazingly slim profile, Apple managed to cram some nifty ports on the new Air.
Accompanying the audio jack on the left side of the MacBook are the new MagSafe 2 connector and the first of two USB 3.0 ports.
On the opposite side, we find an SD card reader, the second USB 3.0 port, and—of course—Apple and Intel's brainchild: the Thunderbolt I/O.
I don't believe that Thunderbolt is really Apple's nor is it proprietary. It's a standard developed with Intel. There are PC motherboards shipping with Thunderbolt ports and I think it's planned to be integrated into all Intel chipsets eventually.
Why the USB3 Ports are not blue colored as the standard on PC? Will be more easily to identify.
Because it's USB 3 & 2. The people that engineer PC hardware simply don't get it. They color code because they have separate USB 3 and 2 ports. In other words, they have monkeys engineering their products.
You do you realize that it makes no difference what so ever on a PC... usb 3.0 architecture on both mac and PC is exactly the same meaning you can use usb 2.0 and 3.0 in a usb 3.0 socket on both.
This is very unlike Apple; even though the MacBook Air is only slightly refreshed, they gave it a new model number: A1466.
We get pretty excited about new model numbers because they make it much easier for us to help people ID their Macs for service.
MagSafe 2 is a luxury reserved (so far) for the new MacBook Air and the Retina display-equipped MacBook Pro.
As you can see, the new MagSafe 2 connector (bottom) is much thinner and wider than its predecessor. This is pretty significant, because the thickness of Apple's devices seems to be limited only by the size of their ports.
Apple sells a $10 MagSafe 2 adapter, so you don't have to throw away your 27" Thunderbolt Display. Phew.
Apple never stops tweaking the details; they moved the symbols from the rear side of the ports to the front. If you're in a pinch and have to differentiate a Mid 2012 MacBook Air from a Mid 2011 model, just look at what side of the ports the symbols are on.
In diesem Schritt verwendetes Werkzeug:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
There was tension in the Air as we encountered a few unknown sized, Apple-proprietary, pentalobe screws on the back of the new Air.
Fortunately, we have tools for that. Our pentalobe screwdriver made quick work of those pesky proprietary screws.
By the way, we don't just make awesome teardowns—we sell parts. And tools! Lots and lots of tools.
Like this handy-dandy electronics tool kit that we used to take apart the new iPad. You know you want one. It'll pay for itself the first time you use it!
We sell Mac parts & upgrades, parts for iPhone screen repair, kits for fixing the infamous Xbox Red Ring of Death, and tons more.
We need your support to continue building the free repair manual for everything in the world.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
After removing the screws, the back comes off to reveal the internals.
Keeping all the screws we removed organized is easy with our Magnetic Project Mat.
As with most mobile devices, the majority of the space is filled by the battery.
The inside of this newly configured Air is very similar to last year, with a few minor layout changes.
A connector and some T5 screws are all that stand between us and ultimate power—or at least the power source for the Air.
This battery is the exact same model as the one found in the Mid 2011 MacBook Air, so it comes as no surprise that the 13" model has the same 7 hour battery life as its predecessor.
Based on Step 7 - I'm assuming the 11inch model has the same method of connection for the battery. Understandably the 11inch battery is smaller - but from what I'm seeing I should be able to replace mine once it starts to act up.
Would this be a correct assumption? That in fact, I can replace the battery in my 11inch one day down the road? Excellent news if so!
At first glance, the 128 GB SSD is almost exactly the same as last year's.
But upon closer inspection, the connector for this model's flash memory module is slightly different than last year!
The SSD looks to be a completely new design. The new unit appears to be based on a SandForce controller chip, but stamped with Toshiba markings.
So, it will be possible to change the SSD, or we cannot find right now that kind of new connector?
Any tip where to buy proper SSD por this MB Air?
Thanks
So, my OWC SSD 240GB 6G don't work with this new connector :-(, it's right?
Thanks
By the way: we also make software for teaching people to do things. Dozuki makes it easy to create vibrant how-to manuals.
Dozuki is great for:
Standardized work instructions: improve quality by documenting how to get things done, one step at a time.
Building product support sites: make your customers love you by teaching them how to do amazing things.
Training and e-learning software: we've used Dozuki to teach over ten million people to repair electronics.
Online community platform: build a knowledge base of expert knowledge with Answers, the Q&A engine that drives the popular iFixit Answers.
We would tell you that this Broadcom BCM 943224 module looks just like the Mid 2011 MacBook Air's wireless board, but you would accuse us of being repetitive.
Instead, let's focus on what's different. Apple rotated the "Assembled in China" sticker 90˚ and flipped the internal code sticker a whopping 180˚!
In case you thought we were joking, taking the EMI shield off reveals the same chips as last year:
Broadcom BCM4322 Intensi-fi® Single-Chip 802.11n Wi-Fi Transceiver
Broadcom BCM20702 Single-Chip Bluetooth 4.0 Processor with Bluetooth Low Energy (BLE) support
Murata antenna switch module
The device in the center of the image (between the two BCM) is a Murata Antenna Switch Module (ASM)
Good eye, Jim, as usual.
In diesem Schritt verwendetes Werkzeug:Spudger$3.99
Next up are the speakers.
The new Air boasts stereo speakers for all your Apple party needs. Just in case you want to party like it's 2011 or 2010...
You may be asking, "What's that black stick being used to remove the speaker?" That is a Spudger. It's ESD safe and heat/solder resistant. It's a must for working with sensitive electronics.
A few more Torx screws hold the lonely fan in place.
We were hoping to find a new asymmetrical fan, and we were not disappointed!
If you're not familiar with all the hype, the "asymmetrical" design of the fan blades is supposed to disperse sound across a wide range of frequencies, rather than just one, making fan noise "hardly perceivable."
Measure the blade gap distances on the fan--I believe it is asymmetrical spacing.
Good call, James. The difference in spacing is only about 0.5 mm, but it's definitely there.
Next out is the left side I/O board, featuring the slimmed down MagSafe 2 port.
Sitting side-by-side with MagSafe 2 and USB 3.0, the standard 3.5 mm headphone jack looks quite plain and outdated. How long must we wait until Apple announces "The New Jack"?
With dictation coming in OSX Mountain Lion, you're going to want to make sure you've got a brand spankin' new microphone.
"MacBook, send a message to my iPhone so that I can talk to Siri."
Boom! There goes the logic board.
Bam! There goes the heat sink.
Even with a new processor lineup, the thermal management system looks pretty much the same as last year. It truly is a testament to modern processor efficiency to see such a small heat sink on a dual-core processor that can crank out up to 2.8 GHz.
Here's what we found on side A of the logic board:
Intel Core i5-3427U 1.8 GHz dual-core processor (Turbo Boost up to 2.80 GHz) with Intel HD Graphics 4000
Intel E201B953 SLJ8B Platform Controller Hub
Intel DSL3510L Thunderbolt controller
Texas Instruments TPS2561 dual channel power switch
Linear Technology LT3957 inverting converter
Flipping the logic board to side B we find:
SMSC USB25138 USB controller
Hynix H5TC2GB3CFR DDR3L SDRAM
MAXIM 15120G
Texas Instruments Stellaris LM4FS1AH microcontroller
Macronics MXIC MX25L6406E serial flash
Texas Instruments TPS51980 synchronous buck controller
Texas Instruments CD3210
Good news everyone! If you're ever faced with a nonfunctional trackpad, It seems replacing the trackpad remains as easy as ever.
A few notable chips we found on the trackpad:
Silicon Storage Technology 25VF020
Cypress Semiconductor CY8C24794 Microcontroller
Broadcom BCM5976A0KU826
The display assembly is screwed to the upper case with six T8 Torx screws.
Because the display assembly is one of the few moving parts in the MacBook Air, these screws have to be pretty staunch.
In order to save weight in the MacBook Air, there is no protective front glass covering the LCD like there is on the MacBook Pro. This is also the reason for the aluminum bezel.
MacBook Air 13" Mid 2012 Repairability Score: 4 out of 10 (10 is easiest to repair).
Once you manage to take off the bottom cover, all the parts are pretty easily replaceable.
Proprietary screws on the case require the right screwdriver.
All the components—including RAM and SSD—are proprietary.
I’m curious about the camera in this laptop. My wife’s macbook air shows no functional camera and I’d like to be able to repair that. Not sure if it’s a loose connection or faulty equipment. Will keep looking but would love a teardown of the display assembly.
11 Kommentare
Is it true that the Intel DSL3510L Thunderbolt controller is a new introduction to the Macbook Air and is capable of driving two additional displays?
If I recall correctly, the previous generation Macbook Air could only drive one.
Sad to hear, that the SSD-connection port has been changed.
So after i've upgraded my 2010er MBA 11" and my late 13" MBA with OWC 240GB SSD-Bladed (3G & 6G) they will be worthless when i wanna buy a small 11" 2012er MBA and upgrade it ? -> Yes !
I can understand that the Retina MBP got a different SSD-Blade size, but changing the connection port within the MBA-family is nonsense.....
Anyone got the appropriate Apple OEM part numbers for the replaceable 128GB, 256GB, and 512GB SSD drives? Looking to upgrade and want to find the correct part numbers (not interested in the OWC module).
The different connector was probably because the SSDs are electronically incompatible, not just to frustrate DIYers.
If anyone can help!!
13" Apple MacBook Air Year 2012 Model# A1466
I need help with knowing where I am able to find the right schematic diagram for an Apple MacBook Air for the Year 2012 Model# A1466??
I have came across some ones for free but do not match up to my circuity's layout.
PS: I addition, does anyone know where the best place to buy replacement circuits for Apple Macs?? May be needing to replace a few capacitors and a resistor shorted by liquid damaged.
If someone that knows can help, That would be great and Thank you,
Charles
2672753399 or
cremensnyder3rd@gmail.com
Hello,
I’m looking for the PFC Connector on the logic board for the trackpad. Where can I get it?
Kind regards,
André (abcdefg@blacktux.de)
how can i differentiate apple macbook air core i5 from a core i7?
What kind of paste can I for the CPU heatsink?
Thank you
Any!
I recommend Arctic
[verlinktes Produkt fehlt oder ist deaktiviert: IF179-010]
Where can I locate a replacement screen. Mine is currently showing the video as ‘folded’ back on itself.
