Zum Hauptinhalt wechseln
Was du brauchst
Angehängtes Dokument
Dieser Teardown ist keine Reparaturanleitung. Um dein MacBook Pro 15" Core Duo Model A1150 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. MacBook Pro 15" Core Duo Model A1150 Teardown, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect the power cord and any other cables connected to the computer
    • Place the computer face down
    • Slide both battery latches away and lift the battery out
    Frag FixBot
    Kommentar hinzufügen
  2. MacBook Pro 15" Core Duo Model A1150 Teardown, Memory: Schritt 2, Bild 1 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Memory: Schritt 2, Bild 2 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Memory: Schritt 2, Bild 3 von 3
    • Remove the three screws from the memory door
    • Remove the door as shown
    • Remove the memory cards by carefully spreading the tabs away from the card
    • Pull the card straight back and out
    Frag FixBot
  3. MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case: Schritt 3, Bild 1 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case: Schritt 3, Bild 2 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case: Schritt 3, Bild 3 von 3
    • Remove the six screws on the bottom and the two in the battery bay
    • Remove the four screws from the side and two on the back
    Frag FixBot
  4. MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case Cont.: Schritt 4, Bild 1 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case Cont.: Schritt 4, Bild 2 von 3 MacBook Pro 15" Core Duo Model A1150 Teardown, Top Case Cont.: Schritt 4, Bild 3 von 3
    • Open the display slightly past 90 degrees and use a spudger to loosen the top case
    • A snapping noise is normal
    • Do not lift the top case once it is free
    • Slowly lift the top case until you can see the ribbon cable, carefully unplug then lift the top case off
    Frag FixBot
  5. MacBook Pro 15" Core Duo Model A1150 Teardown: Schritt 5, Bild 1 von 2 MacBook Pro 15" Core Duo Model A1150 Teardown: Schritt 5, Bild 2 von 2
    • Remove two antenna connectors. Lift straight up
    • Remove one screw and bracket. The card should rise up slightly
    • Pull the card straight out
    Frag FixBot
Angehängte Dokumente
Luke
1.613 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 43
Insgesamt: 4,973
