Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein MacBook Pro 15" Retina Display Mid 2015 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. MacBook Pro 15" Retina Display Mid 2015 Teardown, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 2, Bild 1 von 2 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 2, Bild 2 von 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 3, Bild 1 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 3, Bild 2 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 3, Bild 3 von 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 Teardown, Battery Connector: Schritt 4, Bild 1 von 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 5, Bild 1 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 5, Bild 2 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 5, Bild 3 von 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 Teardown, SSD: Schritt 6, Bild 1 von 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  7. MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 7, Bild 1 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 7, Bild 2 von 3 MacBook Pro 15" Retina Display Mid 2015 Teardown: Schritt 7, Bild 3 von 3
    • Lift the end of the SSD up enough to pass over the speaker directly behind it.
    • Do not lift the SSD too high, or you could damage the contacts or socket.
    • Pull the SSD straight out of its socket on the logic board.
Terry Salt
76 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Errr.. this isn't a teardown. It stops at step 7 "remove the ssd"!!
Dominic Cazenove - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 67
Letzte 30 Tage: 238
Insgesamt: 14,223
