Einleitung
Will show the process of taking apart of computer mouse that uses a ball for the process of tracking motion.
Was du brauchst
Rotate mouse over and locate Trackball cover
Using index fingers and thumb, rotate counter-clockwise
After the Trackball cover has been rotated, pry the lid off using fingernails.
Remove Trackball cover and place to the side.
Angle mouse to eject Trackball from the casing.
Using a Phillips head screwdriver, locate screw hole and unscrew the screw inside.
Lift the two cases apart and place screw to the side.
Remove the wire from the plastic casing near the top of the mouse.
Lift up to remove the PCB which is attached to the mouse.
Place case to the side.
Locate where the wire is connected to the PCB via the white connection.
Pry the connections apart and place the cable to the side.
2 Kommentare
Wow! Someone really worked hard on this guide. Kudos sir.
Yes sir I won't know everything about the machine
