Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Speziell für diesen Teardown benötigte Werkzeuge
  1. Has an additional USB port for charging. Input: 9V 1500mA
    • Has an additional USB port for charging.
    • Input: 9V 1500mA
    • Output: 5V 1000mA
    • Frequency: 100-150kHz
    • USB output: 5V 1000mA
    • Size 145mm X 81mm X 10mm
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Top and bottom shells are separated by  10 plastic clips. To open, insert plastic opening tool or plastic knife and push inward and towards the top shell.
    • Top and bottom shells are separated by 10 plastic clips.
    • To open, insert plastic opening tool or plastic knife and push inward and towards the top shell.
    • Start from near the USB port and work your way around. The corners are pretty hard and the clips are pretty sturdy.
    • Viola! Its open!
    • Holes there are for ventilation for the coil
  4. More pictures. Coil is covered by a foam pad held down by a little glue. Coil is covered by a foam pad held down by a little glue.
    • More pictures.
    • Coil is covered by a foam pad held down by a little glue.
Sean
181 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 4,242
