Was du brauchst
Has an additional USB port for charging.
Input: 9V 1500mA
Output: 5V 1000mA
Frequency: 100-150kHz
USB output: 5V 1000mA
Size 145mm X 81mm X 10mm
Top and bottom shells are separated by 10 plastic clips.
To open, insert plastic opening tool or plastic knife and push inward and towards the top shell.
Start from near the USB port and work your way around. The corners are pretty hard and the clips are pretty sturdy.
Viola! Its open!
Holes there are for ventilation for the coil
