Einleitung
The hair dryer is an electromechanical device that blows ambient or hot hair over damp hair to speed the evaporation of water to dry the hair. Developed during the early-1920s in Germany. After decades of development, the hair dryer becomes a daily device to dry hair and style.
Was du brauchst
Locate the screw on the handle and remove them with a Phillips screwdriver.
Remove the internal switch from the rear portion of the handle.
Remove the lower portion of the handle by sliding the peg out of the slot at the top of the handle.
Separate the iron case with the back case by using 6.5mm flathead screwdriver. Take off the fan after separation.
Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
Separate the back and front case by using the 6.5mm flathead screwdriver.
At this point you can pull the complete electronic sub assembly from the front case.
Coils
