Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Morphy Richards Iron zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Morphy Richards Iron Teardown, Morphy Richards Iron Teardown: Schritt 1, Bild 1 von 1
    • This is the iron we will take apart.
  2. Morphy Richards Iron Teardown: Schritt 2, Bild 1 von 1
    • First remove the rear or the iron using the flathead screwdriver.
  3. Morphy Richards Iron Teardown: Schritt 3, Bild 1 von 1
    • Next remove the cable bridge bracket.
  4. Morphy Richards Iron Teardown: Schritt 4, Bild 1 von 1
    • Next remove the screws from the base. (see arrows for location)
  5. Morphy Richards Iron Teardown: Schritt 5, Bild 1 von 1
    • Next remove the screw the hold the top on.
  6. Morphy Richards Iron Teardown: Schritt 6, Bild 1 von 1
    • To free the long cable remove from terminal block at rear.
  7. Morphy Richards Iron Teardown: Schritt 7, Bild 1 von 1
    • At the front of the iron pull out the buttons for the steam and water.
  8. Morphy Richards Iron Teardown: Schritt 8, Bild 1 von 1
    • Next unclip the button holder (red circle) by undoing the screws (black circle)
  9. Morphy Richards Iron Teardown: Schritt 9, Bild 1 von 1
    • Next remove the bridge clip from the arrows position.
  10. Morphy Richards Iron Teardown: Schritt 10, Bild 1 von 1
    • Next remove the inner button (black circle)
    • Now remove the centre screw (red arrow)
  11. Morphy Richards Iron Teardown: Schritt 11, Bild 1 von 1
    • slide off the cable holder from the cable.
  12. Morphy Richards Iron Teardown: Schritt 12, Bild 1 von 1
    • Disassemble the plug
    • First remove the casing.
    • Now remove the wires from the pins.
    • Next remove the pins.
  13. Morphy Richards Iron Teardown: Schritt 13, Bild 1 von 1
    • Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
  14. Morphy Richards Iron Teardown: Schritt 14, Bild 1 von 1
    • Next take out round selector, this is simply clipped so can be pulled out with pliers.
  15. Morphy Richards Iron Teardown: Schritt 15, Bild 1 von 1
    • Next remove the washer parts at the front of the iron.
    • Take the tubing off.
  16. Morphy Richards Iron Teardown: Schritt 16, Bild 1 von 1
    • Remove the seals for the water pump.
    • Now take pumps out.
  17. Morphy Richards Iron Teardown: Schritt 17, Bild 1 von 1
    • Remove the screw (circled) this will lead to the separation of the base and the top.
  18. Morphy Richards Iron Teardown: Schritt 18, Bild 1 von 1
    • Remove the top of the iron to reveal the under parts.
    • Now remove the rubber seals from the plate.
    • Take out the screws linking to the stainless steel base.
  19. Morphy Richards Iron Teardown: Schritt 19, Bild 1 von 1
    • Remove the terminal block from the wires.
    • Next take off the black section of the iron.
  20. Morphy Richards Iron Teardown: Schritt 20, Bild 1 von 1
    • Now remove the screws from the steel base.
  21. Morphy Richards Iron Teardown: Schritt 21, Bild 1 von 1
    • Next remove each individual part ( mostly wiring)
  22. Morphy Richards Iron Teardown: Schritt 22, Bild 1 von 1
    • All parts at the end of the process.
RIchard fox
278 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 166
Insgesamt: 35,017
