Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Speziell für diesen Teardown benötigte Werkzeuge
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Motorola Moto G 2nd Generation zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove back cover. It's easy, no adhesive and no screws. Remove back cover. It's easy, no adhesive and no screws.
    • Remove back cover. It's easy, no adhesive and no screws.
  2. Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions. Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions. Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
    • Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
  3. Take away the volume button and power button. Take away the volume button and power button.
    • Take away the volume button and power button.
  4. Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive. Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive. Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
    • Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
  5. Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery. Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery. Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
    • Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
  6. At that time, remove the battery with SIM & SD card reader assembly together.
    • At that time, remove the battery with SIM & SD card reader assembly together.
  7. Separate battery and SIM & SD card reader assembly. Separate battery and SIM & SD card reader assembly. Separate battery and SIM & SD card reader assembly.
    • Separate battery and SIM & SD card reader assembly.
  8. Release LCD screen connector from motherboard. Release LCD screen connector from motherboard. Release LCD screen connector from motherboard.
    • Release LCD screen connector from motherboard.
  9. Release sensor flex connector and front camera connector respectively. Release sensor flex connector and front camera connector respectively.
    • Release sensor flex connector and front camera connector respectively.
  10. Remove screws on the motherboard and the motherboard can be removed easily. Remove screws on the motherboard and the motherboard can be removed easily. Remove screws on the motherboard and the motherboard can be removed easily.
    • Remove screws on the motherboard and the motherboard can be removed easily.
  11. Remove rear camera. Remove rear camera. Remove rear camera.
    • Remove rear camera.
  12. Remove front camera and sensor cable. Remove front camera and sensor cable. Remove front camera and sensor cable.
    • Remove front camera and sensor cable.
  13. Remove earpiece and loudspeaker. Remove earpiece and loudspeaker.
    • Remove earpiece and loudspeaker.
  14. Done.
    • Done.
Sophia
43.225 Reputation
62 Anleitungen geschrieben
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
Top View - Antwort
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
T-Mobile Huawei Prism U8651T Teardown
Top View -
Can anyone please tell me where I can get the details of the Antenna used for the GSM connection in this phone? Like the drawing or schematic.
Please I really need this as this phone has poor cell reception.
Amol - Antwort
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
mihaibanditu - Antwort
Where can I get more information about GPS module and its antenna?
Paulo Abner - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 12
Letzten 30 Tage: 56
Insgesamt: 52,187
