Zum Hauptinhalt wechseln
Einführungsvideo
  1. Remove back cover. Moto G3 plastic panel can be easily removed with the fingernails.
    • Remove back cover.
    • Moto G3 plastic panel can be easily removed with the fingernails.
  2. Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath. Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
    • Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
  3. Undo 3 screws by T4 Torx screwdriver. Take away plastic securing part.
    • Undo 3 screws by T4 Torx screwdriver.
    • Take away plastic securing part.
  4. Heat up the LCD screen for a while. Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives. There is LCD screen connector on the left side, so be careful to slide guitar picks.
    • Heat up the LCD screen for a while.
    • Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
    • There is LCD screen connector on the left side, so be careful to slide guitar picks.
  5. Release LCD screen connector firstly. Remove LCD screen. Remove LCD screen.
    • Release LCD screen connector firstly.
    • Remove LCD screen.
  6. Undo 14 screws by T4 Torx screwdriver Pry up motherboard assembly. Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
    • Undo 14 screws by T4 Torx screwdriver
    • Pry up motherboard assembly.
    • Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
  7. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  8. Release battery flex connector. Separate motherboard assembly from back cover assembly.
    • Release battery flex connector.
    • Separate motherboard assembly from back cover assembly.
  9. Undo 3 screws here. Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it. Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
    • Undo 3 screws here.
    • Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
  10. Remove front-facing camera. Remove front-facing camera.
    • Remove front-facing camera.
  11. Remove rear camera. Remove rear camera. Remove rear camera.
    • Remove rear camera.
  12. Remove earpiece. Remove earpiece.
    • Remove earpiece.
  13. Remove loudspeaker. Remove loudspeaker.
    • Remove loudspeaker.
  14. Here is the motherboard. Here is the motherboard.
    • Here is the motherboard.
  15. Use spudger to cut adhesive and pry the battery up. Use spudger to cut adhesive and pry the battery up.
    • Use spudger to cut adhesive and pry the battery up.
  16. Take away headphone jack. Take away headphone jack. Take away headphone jack.
    • Take away headphone jack.
  17. Done
    • Done
Ziellinie
14 weitere Nutzer haben diese Anleitung absolviert.
Witrigs
61.443 Reputation
387 Anleitungen geschrieben
Muito bom, parabéns!
Manoel - Antwort
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
setsuoleandro - Antwort
Wi fi not trun on ..moto g3
Seoni Seoni - Antwort
When you heat up the display, do you heat up the entire display or just around the edges? What heat gun/setting should i use? Can i use a blowdryer?
guest - Antwort
Thanks. ......................
Biswajit Saha - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 10
Letzte 7 Tage: 53
Letzte 30 Tage: 230
Insgesamt: 17,390
