Zum Hauptinhalt wechseln
Motorola Moto G3 Teardown
Was du brauchst
Einführungsvideo
  1. Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: Schritt 1, Bild 1 von 2 Motorola Moto G3 Teardown, Motorola Moto G3 Teardown: Schritt 1, Bild 2 von 2
    • Remove back cover.
    • Moto G3 plastic panel can be easily removed with the fingernails.
  2. Motorola Moto G3 Teardown: Schritt 2, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 2, Bild 2 von 2
    • Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
  3. Motorola Moto G3 Teardown: Schritt 3, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 3, Bild 2 von 2
    • Undo 3 screws by T4 Torx screwdriver.
    • Take away plastic securing part.
  4. Motorola Moto G3 Teardown: Schritt 4, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 4, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 4, Bild 3 von 3
    • Heat up the LCD screen for a while.
    • Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
    • There is LCD screen connector on the left side, so be careful to slide guitar picks.
    start prying the screen off from the top corners very gently. I started from the bottom and shattered the glass
    Bob Mcroy - Antwort
    A que temperatura debe estar el aire caliente? Durante cuánto tiempo?
    Luis - Antwort
  5. Motorola Moto G3 Teardown: Schritt 5, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 5, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 5, Bild 3 von 3
    • Release LCD screen connector firstly.
    • Remove LCD screen.
  6. Motorola Moto G3 Teardown: Schritt 6, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 6, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 6, Bild 3 von 3
    • Undo 14 screws by T4 Torx screwdriver
    • Pry up motherboard assembly.
    • Battery flex connector is connected with motherboard, so be careful to pry the assembly up.
  7. Motorola Moto G3 Teardown: Schritt 7, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 7, Bild 2 von 2
    • Release battery flex connector.
    • Separate motherboard assembly from back cover assembly.
  8. Motorola Moto G3 Teardown: Schritt 8, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 8, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 8, Bild 3 von 3
    • Undo 3 screws here.
    • Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
  9. Motorola Moto G3 Teardown: Schritt 9, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 9, Bild 2 von 2
    • Remove front-facing camera.
  10. Motorola Moto G3 Teardown: Schritt 10, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 10, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 10, Bild 3 von 3
    • Remove rear camera.
  11. Motorola Moto G3 Teardown: Schritt 11, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 11, Bild 2 von 2
    • Remove earpiece.
  12. Motorola Moto G3 Teardown: Schritt 12, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 12, Bild 2 von 2
    • Remove loudspeaker.
  13. Motorola Moto G3 Teardown: Schritt 13, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 13, Bild 2 von 2
    • Here is the motherboard.
  14. Motorola Moto G3 Teardown: Schritt 14, Bild 1 von 2 Motorola Moto G3 Teardown: Schritt 14, Bild 2 von 2
    • Use spudger to cut adhesive and pry the battery up.
  15. Motorola Moto G3 Teardown: Schritt 15, Bild 1 von 3 Motorola Moto G3 Teardown: Schritt 15, Bild 2 von 3 Motorola Moto G3 Teardown: Schritt 15, Bild 3 von 3
    • Take away headphone jack.
  16. Motorola Moto G3 Teardown: Schritt 16, Bild 1 von 1
    • Done
Ziellinie
18 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.454 Reputation
378 Anleitungen geschrieben
7 Kommentare
Muito bom, parabéns!
Manoel - Antwort
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
setsuoleandro - Antwort
Wi fi not trun on ..moto g3
Seoni Seoni - Antwort
When you heat up the display, do you heat up the entire display or just around the edges? What heat gun/setting should i use? Can i use a blowdryer?
guest - Antwort
Thanks. ......................
Biswajit Saha - Antwort
Anyone know where the GPS antenna is? I'm having issues with intermittent loss of GPS signal and would like to try re-seating or replacing the antenna.
saml604 - Antwort
Excelente tutorial Gracias
Oscar Lopez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 23,963
