Was du brauchst
Einführungsvideo
Remove camera&flashlight metal cover. Use tweezers to cut strong adhesives underneath.
Heat up the LCD screen for a while.
Then with the help of suction cup, insert guitar picks to open a gap. Slide guitar picks or plastic opening tool to cut strong adhesives.
Release battery flex connector.
Separate motherboard assembly from back cover assembly.
Undo 3 screws here.
Use spudger to cut adhesives and pry the SIM&SD card reader board, then remove it.
18 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
Could you guys tell me if the main speaker, at the bottom, has a special protection agains water spills, like a membrane or so, or is it pretty fine too spill water there?
Wi fi not trun on ..moto g3
Thanks. ......................
Excelente tutorial Gracias
