Einleitung
This guide is for educational purposes and should not be used as a repair guide.
Was du brauchst
Place your thumb in the indent located at bottom left corner of the back cover.
The cover will pop up and begin to lift.
Continue to slide your fingers up the sides to remove the back cover.
With tweezers, slide under all sides of the lens to loosen it.
Pulls the lens towards you to remove the lens.
Using the screwdriver equipped with the T4 head drill bit, begin unscrewing the screws on the back panel.
After all the screws are removed from the back panel, lift the back panel off.
Using the tweezers, unhook the twisted red and black wire from under the black plastic pieces that are holding it down.
Using the tweezers, disconnect the wire from its connective port.
Use the spudger to lift the battery out.
Using the tweezers, pull up on the clasp that is holding the motherboard down.
Using the tweezers, pull up on the clasp that is connecting the motherboard to the front-facing camera.
Using the tweezers, remove the red and black wiring from the bottom of the phone by the charging port.
Using the tweezers pull up on the three corners of the motherboard until it comes out.
