Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Motorola i450 Boost Mobile zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Motorola i450 Boost Mobile Teardown, Antenna: Schritt 1, Bild 1 von 3 Motorola i450 Boost Mobile Teardown, Antenna: Schritt 1, Bild 2 von 3 Motorola i450 Boost Mobile Teardown, Antenna: Schritt 1, Bild 3 von 3
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Teardown: Schritt 2, Bild 1 von 3 Motorola i450 Boost Mobile Teardown: Schritt 2, Bild 2 von 3 Motorola i450 Boost Mobile Teardown: Schritt 2, Bild 3 von 3
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
  3. Motorola i450 Boost Mobile Teardown, Back Cover: Schritt 3, Bild 1 von 3 Motorola i450 Boost Mobile Teardown, Back Cover: Schritt 3, Bild 2 von 3 Motorola i450 Boost Mobile Teardown, Back Cover: Schritt 3, Bild 3 von 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  4. Motorola i450 Boost Mobile Teardown, Battery: Schritt 4, Bild 1 von 3 Motorola i450 Boost Mobile Teardown, Battery: Schritt 4, Bild 2 von 3 Motorola i450 Boost Mobile Teardown, Battery: Schritt 4, Bild 3 von 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  5. Motorola i450 Boost Mobile Teardown, SIM Card: Schritt 5, Bild 1 von 2 Motorola i450 Boost Mobile Teardown, SIM Card: Schritt 5, Bild 2 von 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  6. Motorola i450 Boost Mobile Teardown: Schritt 6, Bild 1 von 3 Motorola i450 Boost Mobile Teardown: Schritt 6, Bild 2 von 3 Motorola i450 Boost Mobile Teardown: Schritt 6, Bild 3 von 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  7. Motorola i450 Boost Mobile Teardown, Circuit Board: Schritt 7, Bild 1 von 1
    • Extend the antenna.
  8. Motorola i450 Boost Mobile Teardown: Schritt 8, Bild 1 von 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  9. Motorola i450 Boost Mobile Teardown: Schritt 9, Bild 1 von 3 Motorola i450 Boost Mobile Teardown: Schritt 9, Bild 2 von 3 Motorola i450 Boost Mobile Teardown: Schritt 9, Bild 3 von 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  10. Motorola i450 Boost Mobile Teardown, Keypad: Schritt 10, Bild 1 von 3 Motorola i450 Boost Mobile Teardown, Keypad: Schritt 10, Bild 2 von 3 Motorola i450 Boost Mobile Teardown, Keypad: Schritt 10, Bild 3 von 3
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
  11. Motorola i450 Boost Mobile Teardown, Motorola i450 Boost Mobile Teardown: Schritt 11, Bild 1 von 1
    • Exploded view of all phone components.
Clemson, Team 15-2, Benson Fall 2012 Mitglied von Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 1,280
