Einleitung
NeXT Computer was founded in October of 1985 when Steve Jobs was forced out of Apple by John Scully. He started NeXT as a high-end computer company targeted at the University/Scientist/Computing Industry. NeXT only ever released , the NeXTStation, and The NeXTCube, in different variations. NeXT computers were high-end workstation computers, and only a few thousand were ever sold. The NeXTStation featured a, though the Turbo NeXTStation featured a68040. There were color and non-color variations of the NeXTStation. The world's first web server was created by Tim Berners-Lee, at CERN on a NeXTCube. NeXT computers were used to make games like Doom, and Wolfenstein. This is my&W NeXTStation. Mac OS X Is based off of NeXTStep, the NeXT OS.
Was du brauchst
The NeXTStation, this is a great addition to any computer collection.
Turn the NeXTStation around, and remove this screw:
Then, lift the top cover of the computer. This will reveal the guts.
The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
I find notes in everything!
Removing the hard drive:
The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
Remove all of the cables from the logic board.
Then remove this screw.
Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
Removing the floppy disk drive:
The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
Remove the floppy cable.
Then, remove this screw.
Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
Removing the logic board:
Remove the power supply connector. Just lift it straight up, and it should come free.
Remove this screw.
Lift the end of the logic board(away from the ports), and slide it away from the ports.
Now, set the board aside.
The Logic Board Overview:
The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
The CPU: Motorola XC68040RC25
The Co-Procesor: MB610313
Motorola Chips
Intel Chips
AMD Chips (Intel and AMD In the same computer?)
Fujitsu Chips
Made in the USA, you don't see this anymore.
The Serial #
Looks like my NeXTStation came from WilTel.
It is model # N1100
3 Kommentare zur Anleitung
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Zitat von Juddy:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
