Speziell für diesen Teardown benötigte Werkzeuge
Einführungsvideo
Einleitung
For the official iFixit teardown of the Nexus 5X, click here.
Come to blog of Witrigs to see more detailed steps about LG Nexus 5X spare parts replacement.
Twist off 10 Phillips screws together.
Pry up bottom half and upper half of middle frame.
Release battery connector.
Pry up and remove battery ( Adhesive underneath is not strong).
Loosen LCD screen connector and rear camera connector.
Pry up and remove motherboard assembly.
The adhesive underneath rear camera is strong. Be careful to pry up and remove it.
Adhesive underneath vibration motor is a little bit strong. Pry it up carefully.
The sticker underneath LCD with digitizer is a little bit strong, so use heat gun to soften it for a few minutes.
With the help of suction cup and guitar picks, remove LCD screen carefully.
3 Kommentare
Where is the camera's microphone placed? I replaced my camera module and now I hear noises when shooting video. May it happen because I haven't glue it back? It happens even while the phone is static, but video is fine.
I suggest that you can take it off and put some new adhesive on the backside of rear camera, and then see what happened.
Witrigs -
Um. You have a teardown that is not the iFixit official teardown, but has the same title, and links to your offsite blog/YT channel? Isn't that a bit misleading?
I think you should rename this Guide so as to not create confusion with the iFixit article with the same title. My 2¢.
