Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Nikon Coolpix 3200 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nikon Coolpix 3200 Teardown, Nikon Coolpix 3200 Teardown: Schritt 1, Bild 1 von 1
    • Use a small Philips screwdriver to remove the screws from the base of the camera.
  2. Nikon Coolpix 3200 Teardown: Schritt 2, Bild 1 von 1
    • Use a small Philips screwdriver to remove the screws from the side of the camera where the computer lead is.
  3. Nikon Coolpix 3200 Teardown: Schritt 3, Bild 1 von 1
    • Use a small Philips screwdriver to remove the two screws from the side of the camera where the card reader is.
  4. Nikon Coolpix 3200 Teardown: Schritt 4, Bild 1 von 1
    • Pry apart the outer casing. A gray plastic threaded piece (used to attach camera to a tripod) will fall out.
  5. Nikon Coolpix 3200 Teardown: Schritt 5, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two silver screws that connect the circuit board to the outer front casing.
  6. Nikon Coolpix 3200 Teardown: Schritt 6, Bild 1 von 1
    • Pry apart the front outer casing from the circuit board. The camera will now be in three pieces.
  7. Nikon Coolpix 3200 Teardown: Schritt 7, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 7, Bild 2 von 2
    • Pull the connecting strip on the circuit board which connects it to the back outer casing.
  8. Nikon Coolpix 3200 Teardown: Schritt 8, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 8, Bild 2 von 2
    • Use a Philips screwdriver to remove the two screws next to the computer port and the brass screw on the circuit board.
  9. Nikon Coolpix 3200 Teardown: Schritt 9, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 9, Bild 2 von 2
    • Use a Phillips screwdriver to unscrew the three screws that connect the outer lens rim to the front casing.
  10. Nikon Coolpix 3200 Teardown: Schritt 10, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 10, Bild 2 von 2
    • Use a Philips screwdriver to remove the three screws that hold the flash cover to the outer front casing.
  11. Nikon Coolpix 3200 Teardown: Schritt 11, Bild 1 von 1
    • Open the lid of the battery compartment and use a Philips screwdriver to remove the two screws at the bottom.
  12. Nikon Coolpix 3200 Teardown: Schritt 12, Bild 1 von 1
    • Use a Phillips screwdriver to unscrew the two screws that connect the inside battery casing to the front of the outer casing.
  13. Nikon Coolpix 3200 Teardown: Schritt 13, Bild 1 von 1
    • Pull off the battery casing from the inside of the outer front casing. The circuit board, battery casing, and front outer casing will be attached by a connecting strip along with red and black wires.
  14. Nikon Coolpix 3200 Teardown: Schritt 14, Bild 1 von 1
    • Use scissors to cut the red and black wires away from the battery points of contact.
  15. Nikon Coolpix 3200 Teardown: Schritt 15, Bild 1 von 1
    • Pull the connecting strip away from the circuit board to separate it from the front casing.
  16. Nikon Coolpix 3200 Teardown: Schritt 16, Bild 1 von 1
    • Use a Philips screwdriver to unscrew the two screws that connect the photo button to the outer front casing.
  17. Nikon Coolpix 3200 Teardown: Schritt 17, Bild 1 von 1
    • Firmly press on the photo button and this component will pop out.
  18. Nikon Coolpix 3200 Teardown: Schritt 18, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 18, Bild 2 von 2
    • Use a scalpel to pry apart the metal inner part of the button from the plastic outer piece.
  19. Nikon Coolpix 3200 Teardown: Schritt 19, Bild 1 von 2 Nikon Coolpix 3200 Teardown: Schritt 19, Bild 2 von 2
    • Use your fingernails to peel the outer rim from the front casing.
    • Pull the connecting strip out of the circuit board to separate it from the LCD screen.
    • Use your fingernails to pry apart the back metal piece of the screen (covered by a black plastic film) from the front section of the screen.
  20. Nikon Coolpix 3200 Teardown: Schritt 22, Bild 1 von 1
    • Pry apart the back black piece and front white piece of the screen. Inside the screen there are four sheets of plastic: one opaque, two mirrored, and one thicker plastic sheet which has a foil piece attached to it.
    • Use a hammer and chisel to separate the lens piece of the camera from the circuit board.
    • Use your fingernails to pry off the motor, motor cover, and flash piece from the lens piece of the camera.
Milly Whitehead
47 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Oh, and then just do everything in reverse to put it back together again? That hammer and chisel bit bothers me a bit.
mrs_prolo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 46
Insgesamt: 6,329
