Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Nintendo Game Console Accessory zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nintendo 64 Transfer Pak Teardown, Remove outside screws: Schritt 1, Bild 1 von 1
    • On the side where you can enter the gameboy cartridges remove the 4 screws ( These are Y screw, you can use a Y 2.0 or 2.3 head). The top cover should come of after.
  2. Nintendo 64 Transfer Pak Teardown, Remove ribbon cable and board.: Schritt 2, Bild 1 von 1
    • Pull back the 2 small plastic levers carefully. After you can eject the ribbon cable and remove the board.
  3. Nintendo 64 Transfer Pak Teardown, Remove ribbon cable from backside: Schritt 3, Bild 1 von 1
    • After the board is removed you can access the bracket that holds down the connector attached to the ribbon cable. You can remove this by unscrewing the screw on the bracket using a PH0 head
  4. Nintendo 64 Transfer Pak Teardown, Remove iron protection plate: Schritt 4, Bild 1 von 1
    • On the removed top cover from step 1 remove the 2 screw as shown with a PH0 head.
  5. Nintendo 64 Transfer Pak Teardown, Final Teardown view: Schritt 5, Bild 1 von 1
    • List of all the parts separately.
Sam Thielemans
121 Reputation
1 Anleitung geschrieben
3 Kommentare zur Anleitung
I opened my for the sole purpose of cleaning the contacts only so I never unscrewed the metal plating. The listed screws here were incorrect for me.
For the Tri screws, I used Y0
For the Philips screws, I used PH1.
I nearly striped the Philips screw with the PH00 as stated here.
Ice21 - Antwort Teilen
Oh, that's sad to hear you nearly striped.
The listed screws in the article are the one founf by me when unpacking. as well as using the ph00 head.
This is an EUR pack, not sure if yours is too, maybe there are differences in different model no's
Sam Thielemans - Teilen
I think that's the case. Mine's U.S.. Weird that they use different screw types for different regions.
Ice21 - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 893
