Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Nintendo Wii Remote zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nyko Wand Teardown, Removing battery cover and back plate: Schritt 1, Bild 1 von 3 Nyko Wand Teardown, Removing battery cover and back plate: Schritt 1, Bild 2 von 3 Nyko Wand Teardown, Removing battery cover and back plate: Schritt 1, Bild 3 von 3
    • First flip controller so that the back plate faces you
    • Remove the battery cover by pushing up on the bottom plate
  2. Nyko Wand Teardown: Schritt 2, Bild 1 von 2 Nyko Wand Teardown: Schritt 2, Bild 2 von 2
    • Remove both batteries if their are any inside the remote .
    • To remove them press down on the positive end then pull to take out
  3. Nyko Wand Teardown: Schritt 3, Bild 1 von 2 Nyko Wand Teardown: Schritt 3, Bild 2 von 2
    • Using the tri-point Y1 Screw driver remove the two center screws by turning counter clock wise
    • Repeat process for bottom two
  4. Nyko Wand Teardown: Schritt 4, Bild 1 von 3 Nyko Wand Teardown: Schritt 4, Bild 2 von 3 Nyko Wand Teardown: Schritt 4, Bild 3 von 3
    • To fully take off the back piece you will have to use your flat head screw driver and gently go along the edge and unclip it.
    • Gently pull out the whole circuit board ( be careful you may break or rip a wire if you pull to hard )
    • {CAUTION :WATCH OUT FOR SMALL PARTS}
  5. Nyko Wand Teardown: Schritt 5, Bild 1 von 3 Nyko Wand Teardown: Schritt 5, Bild 2 von 3 Nyko Wand Teardown: Schritt 5, Bild 3 von 3
    • To remove the buttons you will simply have to take off the grey silicon cover.
    • To remove the small speaker you can simply pull up .
    • CAUTION : FOR SMALLER BUTTONS LIKE THE VOLUME ONES .
  6. Nyko Wand Teardown: Schritt 6, Bild 1 von 2 Nyko Wand Teardown: Schritt 6, Bild 2 von 2
    • Gently pry the buttons upwards ,removing the buttons from its holding slot.
    • CAUTION : WATCH OUT FOR SMALL BUTTONS !
    • IF YOU WANT TO REBUILD IT FOLLOW STEPS 1-7 BACKWORDS.
Demian De La Vega
143 Reputation
1 Anleitung geschrieben
Ein Kommentar
good¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
RIGO NOLASCO - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 2,389
