Einleitung
In this tutorial, I will show you how to disassemble the Nokia 3210.
Was du brauchst
Remove these screws. These are Torx T6. You'll need this screwdriver to remove them.
If you remove the plate, you can see the Motherboard. Remove the Motherboard with a small flathead screwdriver or a spudger. (A spudger is recommended).
Here's the PCB with removed EMI shields.
CCONT NMP70467 Power Management IC
NMP0581 Power Supply IC
BGY252 and BGY 262 UHF Amplifier
Other side of the PCB.
Hitachi HWYN202A 900MHz Duplexer
Intel F160B3TA Flash
Atmel 24C128 EPROM
Samsung KM68U1000 SRAM
Buzzer MZT-03C
Texas Instruments MAD2PRI Microcontroller (ARM Based)
2 Kommentare
No way! Nokia 3210!!!!!!
