Was du brauchst
Remove the front cover with a small flathead screwdriver or case opener.
If you look at it from the back you can simply use your finger to pull the front cover off from the bottom left so you don't scratch the plastic with the screwdriver.
Now you can pull this part off.
There are 3 tabs on each side of the lcd, you can gently try lifting the tabs out from one side and it should come out.
To see the IC's on the PCB, we remove the EMI Shields with a small flathead screwdriver.
Renesas 08125BN Power Amplifier
HAGAR 4370781 Signaling Processor
Kyocera KEU27260
CCONT NMP70719 Power Management IC
ST M28W320ECT Flash Memory
EMLSI EM641FU16E CMOS Static RAM
Texas Instruments MAD2WDI C GSM Baseband Processor
