Einleitung
Teardown !! this guide will teach you how to disassemble your phone :)
Was du brauchst
Remove the 8 Torx T5 screws
Insert a guitar pick between the frame of the phone
You have to pry until the frame separates
Pry on the right side to remove the Motherboard
remove the cable by pushing it down
to remove the screen we will have to push it from the inside out
since we push it, a space will be created between the screen and the frame, there we will put a guitar pick
the next thing is to move the pua around the frame to separate the screen
100%
Hier starten ›
