Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Nokia Lumia 520 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Nokia Lumia 520 Teardown, Power Phone Down: Schritt 1, Bild 1 von 1
    • Turn the phone completely off. To do this, either manually hold down the power button, or remove the battery.
    • To remove the battery: At the top corner of your phone, put the nail of your index finger in the seam between the screen frame and the back cover. Press the middle of the back cover, and bend the cover to loosen the top hooks. Remove the cover and lift the battery out.
    • Do not use any sharp tools, because they will damage the screen.
  2. Nokia Lumia 520 Teardown, Remove the SIM and Memory Cards: Schritt 2, Bild 1 von 1
    • Once the battery is removed, push the SIM card or memory card into its respective slot. The card will then pop out. Remove the card from the phone.
  3. Nokia Lumia 520 Teardown, Remove the Screws: Schritt 3, Bild 1 von 1
    • The phone is assembled with eight screws. Using the T4 Torx Screwdriver, remove all eight screws from the back cover. The three small thread screws (red arrows) are fixed on the LCD panel. The four big thread screws (blue arrows) are fixed on the touch screen's frame.
  4. Nokia Lumia 520 Teardown, Remove the Plastic Back Plate: Schritt 4, Bild 1 von 1
    • A plastic back plate lies beneath the external back cover. To remove this, place the Plastic Opening Tool between the plastic back plate and the clear plastic tabs on the side of the phone (designated by red arrows). Gently lift up and remove the plastic back plate.
  5. Nokia Lumia 520 Teardown, Remove the Cables and Motherboard: Schritt 5, Bild 1 von 1
    • The motherboard is connected to the phone via the LCD cable and touch screen cable. To remove these cables, gently lift them up using the Plastic Opening Tool.
    • Using the Plastic Opening Tool, lift the clear plastic tabs (shown in Step 4) from around the motherboard. Now, you can gently lift the motherboard from the phone.
  6. Nokia Lumia 520 Teardown, Separate the Remaining Pieces: Schritt 6, Bild 1 von 1
    • There should now be three pieces linked with plastic grips. Using the Plastic Opening Tool, carefully separate these pieces.
    • Take extra care in handling the LCD.
  7. Nokia Lumia 520 Teardown, Remove the Outside Frame: Schritt 7, Bild 1 von 1
    • The outside frame is glued around the edges to the touch screen. Carefully separate the two pieces using the Cutter Blade.
    • If you are changing the digital screen, remove the glue from around the frame completely.
  8. Nokia Lumia 520 Teardown, Replace Parts: Schritt 8, Bild 1 von 1
    • Your phone is now in seven main pieces that can be easily replaced independently.
Nico Gallaud
548 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 62,921
