Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein OWC Thunderbolt 3 Pro Dock zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. OWC Thunderbolt 3 Pro Dock Teardown, The start: Schritt 1, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, The start: Schritt 1, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, The start: Schritt 1, Bild 3 von 3
    • Flip dock upside down and remove rubber feet
  2. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: Schritt 2, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: Schritt 2, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: Schritt 2, Bild 3 von 3
    • Remove bottom plate screws and remove bottom plate
    • Make sure to use a TORX TR8 head for the bottom screws
  3. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: Schritt 3, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: Schritt 3, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: Schritt 3, Bild 3 von 3
    • Remove the mainboard and its three screws
    • Use a TORX TR8 for all of these screws
    • Make sure to unplug the fan on the other side as it is still connected to the chassis, it may need some persuasion as the connector is really in there
    • When removing the mainboard be gentle as the front I/O sits flush to the chassis otherwise you might damage it.
  4. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: Schritt 4, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: Schritt 4, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: Schritt 4, Bild 3 von 3
    • Remove the four TORX TR8 screws
    • Pry the top plate away from the main chassis, this may take some persuasion as the top plate is glued in a bit
  5. OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: Schritt 5, Bild 1 von 2 OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: Schritt 5, Bild 2 von 2
    • Remove the two TORX TR8 screws to remove the heatsink
    • It is highly recommended to clean the surface from whatever residue the thermal pad has left behind to increase longevity of the dock
  6. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: Schritt 6, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: Schritt 6, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: Schritt 6, Bild 3 von 3
    • Switch to a TORX TR10 bit for the fan screws
    • The fan model is a sunon HA40101V4-1D070-G99
    • When the screws are out the fan should just fall out
  7. OWC Thunderbolt 3 Pro Dock Teardown, Everything spread out: Schritt 7, Bild 1 von 1
  8. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: Schritt 8, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: Schritt 8, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: Schritt 8, Bild 3 von 3
    • sample text, the photos speak for themselves
    • The 10Gbe NIC is the Aquantia AQC107S-B1-C
  9. OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: Schritt 9, Bild 1 von 2 OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: Schritt 9, Bild 2 von 2
    • Insert wisdom here. - indeed
  10. OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: Schritt 10, Bild 1 von 2 OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: Schritt 10, Bild 2 von 2
    • I cant figure out how to put more than 3 pics in one step, so the ended up here.
  11. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: Schritt 11, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: Schritt 11, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: Schritt 11, Bild 3 von 3
    • Support the heatsink and line it up with the holes on the top of the chassis
    • Re-install the two TORX TR8 screws to hold in the heatsink
  12. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: Schritt 12, Bild 1 von 2 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: Schritt 12, Bild 2 von 2
    • Line up the fan with the holes
    • Screw the fan back in with the TORX TR10 screws
  13. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: Schritt 13, Bild 1 von 2 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: Schritt 13, Bild 2 von 2
    • Line up the top lid with the main chassis, make sure to have the fan vent in the correct orientation so it can breathe.
    • Screw the lid back in with the four TORX TR8 screws
  14. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: Schritt 14, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: Schritt 14, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: Schritt 14, Bild 3 von 3
    • Put the mainboard back into the main chassis, make sure to be gentile and line up the rear I/O first and then slowly lower in the other side.
    • Secure the mainboard with the 3 TORX TR8 screws. - no you arent missing any the rest of the screws go through the bottom cover
  15. OWC Thunderbolt 3 Pro Dock Teardown: Schritt 15, Bild 1 von 3 OWC Thunderbolt 3 Pro Dock Teardown: Schritt 15, Bild 2 von 3 OWC Thunderbolt 3 Pro Dock Teardown: Schritt 15, Bild 3 von 3
    • Line up the bottom cover, !make sure to use the orientation that is shown in the photo otherwise it will not line up!
    • Secure the bottom cover with the four TORX TR8 screws
    • Re-install the rubber feet, you might want to put a bit of glue on these to keep them on when moving around
Robust
688 Reputation
3 Anleitungen geschrieben
CV22 Mitglied von CV22
Community
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 75
Insgesamt: 240
