Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein OnePlus 6 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. OnePlus 6 Teardown, OnePlus 6 Teardown: Schritt 1, Bild 1 von 3 OnePlus 6 Teardown, OnePlus 6 Teardown: Schritt 1, Bild 2 von 3 OnePlus 6 Teardown, OnePlus 6 Teardown: Schritt 1, Bild 3 von 3
    • OnePlus is known for adding up a lot of flagship-phone features while subtracting the flagship-phone price, and the 6's specs don't disappoint:
    • 6.28” Samsung-made AMOLED display with 2280 x 1080 resolution (402 ppi) and 2.5D Gorilla Glass 5
    • Octa-core, 64-bit Qualcomm Snapdragon 845 processor with 6 GB or 8 GB LPDDR4X RAM
    • Dual main camera with 16 MP (ƒ/1.7 with OIS) and 20 MP (ƒ/1.7) modules; 16 MP (ƒ/2.0) selfie camera
    • 64 GB, 128 GB, or 256 GB built-in storage
    • USB Type-C and 3.5 mm audio ports
    • OxygenOS based on Android Oreo 8.1
  2. OnePlus 6 Teardown: Schritt 2, Bild 1 von 3 OnePlus 6 Teardown: Schritt 2, Bild 2 von 3 OnePlus 6 Teardown: Schritt 2, Bild 3 von 3
    • Around back we have a camera bump that looks a tad Apple-like, paired with a fingerprint sensor in a layout and location reminiscent of other Android flagships.
    • NFC in the camera you say? Thanks for the tip—we'll keep an eye out for that during the following "unauthorized disassembly."
    • On the bottom: headphone jack (yay!) and USB Type-C.
    • Industrial design fans might note that despite its "budget" classification, OnePlus managed to get those components aligned better than its (much more expensive) Samsung counterparts.
  3. OnePlus 6 Teardown: Schritt 3, Bild 1 von 3 OnePlus 6 Teardown: Schritt 3, Bild 2 von 3 OnePlus 6 Teardown: Schritt 3, Bild 3 von 3
    • No need to go in blind when you have X-ray vision—our friends at Creative Electron give us an overview of this smartphone's terrain.
    • Everything looks pretty standard—except for the huge sliding mechanism for the alert slider! If we didn't know any better we'd have guessed it was some kind of linear actuator.
    • Satisfied with our virtual foray into the phone, we turn to the SIM card tray and find the first evidence of the OnePlus 6's rumored water resistance—an integrated rubber gasket.
    • OnePlus doesn't list an official IP rating for the phone, but it's already clear they've put some thought into guarding the insides.
  4. OnePlus 6 Teardown: Schritt 4, Bild 1 von 3 OnePlus 6 Teardown: Schritt 4, Bild 2 von 3 OnePlus 6 Teardown: Schritt 4, Bild 3 von 3
    • Android phone with a glass back? Gone is the classic OnePlus metal casing! But we've seen this before...
    • ...and we have a well-tested solution. The heat gun softens things up and the iSclack and opening pick take care of the rest.
    • We lift the back in trepidation, waiting for the familiar tug of a fingerprint sensor cable.
    • But we're pleasantly surprised—the OnePlus 6 comes with a cable long enough to completely remove the back without worrying about tearing the cable.
    • Breakable glass backs are the pits, although this one's far easier to repair than the ones on recent iPhones. (At $549, an iPhone X back glass replacement costs more than this entire phone.)
  5. OnePlus 6 Teardown: Schritt 5, Bild 1 von 3 OnePlus 6 Teardown: Schritt 5, Bild 2 von 3 OnePlus 6 Teardown: Schritt 5, Bild 3 von 3
    • We pop off a nice red bracket to free that lengthy fingerprint sensor cable, and spy the NFC antenna OnePlus so graciously pointed out.
    • Prior OnePlus antennas did just fine without a glass back (which isn't even for wireless charging). So this glass seems to be mainly just for looks. And cracking.
    • The friendly green tab on this relatively accessible battery says, "由此拉起可拆出电池". This translates to "Pull up and out to remove the battery."
    • This does not translate to "battery is not removable"—as is written in English in the bottom right corner.
    • Despite inconsistent labeling, this battery should be consistently easy to remove with that pull tab—it's only lightly adhered in place. Here OnePlus decidedly one-ups its competition.
    • However, the battery falls behind its peers in capacity, with 12.70 Wh—slightly under the Galaxy S9+ (13.48 Wh) and Google Pixel 2 XL (13.6 Wh).
  6. OnePlus 6 Teardown: Schritt 6, Bild 1 von 3 OnePlus 6 Teardown: Schritt 6, Bild 2 von 3 OnePlus 6 Teardown: Schritt 6, Bild 3 von 3
    • Nine Phillips screws bite the dust and the plastic antenna frame doesn't budge. But a secret tenth screw behind a liquid damage indicator grants access.
    • Under the plastic midframe, we get up-close and personal with that oversized slider mechanism.
    • The slider button moves a hefty metal plunger, which flips a mechanical switch soldered to the motherboard. The X-ray image provides an even better view.
    • Why the seemingly overwrought design? Is it something to do with ingress protection? Or maybe it gives the switch better tactile feedback? Share your best guesses in the comments.
    The switch design is a result of the small (narrow) switch needing to move a slider with very distinct detente points. Moving that plunger keeps the switch moving more linearly (more of a push/pull, as opposed to a lever-action, which puts angular stress) and ensures easier finding/stopping the middle position. Very clever design.
    Chad Kemp - Antwort
    Now that we have an entirely logical answer, here’s a decidedly more illogical but fun possibility:
    I’m going to go with a more off-the-wall and Goldberg-ian idea - the metal plunger is designed to be used with a docking station with a moveable magnet to simultaneously help align the phone for wireless charging and also allow the docking station to move the alert switch in response to a pre-programmed user schedule. Entirely unnecessary and far from pragmatic but, woah! Right?!
    Shawn B - Antwort
  7. OnePlus 6 Teardown: Schritt 7, Bild 1 von 3 OnePlus 6 Teardown: Schritt 7, Bild 2 von 3 OnePlus 6 Teardown: Schritt 7, Bild 3 von 3
    Can i get this part replaced?
    Garvon Douglas - Antwort
    Can I replace my 64gb memory chip with 128gb?
    Is it practical?
    Raees Neelambra - Antwort
  8. OnePlus 6 Teardown: Schritt 8, Bild 1 von 2 OnePlus 6 Teardown: Schritt 8, Bild 2 von 2
    • Next we flip the board and check out the rest of its chips:
    • Qualcomm WCN3990 2x2 802.11ac Wi-Fi with MU-MIMO companion
    • Qualcomm SDR845 RF transceiver
    • Qualcomm PM8005 PMIC
    • Qualcomm PM845 power management
    • Skyworks SKY78160-11 WLAN power amplification module
    • AVAGO AFEM-9046 front end module
    • AVAGO AFEM-9036 front end module
  9. OnePlus 6 Teardown: Schritt 9, Bild 1 von 2 OnePlus 6 Teardown: Schritt 9, Bild 2 von 2
    • IC Identification, pt. 2:
    • Skyworks SKY85814-11 WiFi dual-band 802.11ac front-end module
    • Qualcomm QET4100 envelope tracker
    • STMicroelectronics STM8S003F3 8-bit Microcontroller w/ 8 Kb flash
    • Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
    • Texas Instruments TPS65633B AMOLED display power supply
    • Texas Instruments TXS0104E 4-bit bidirectional voltage-level translator
    • Knowles MEMS microphone
  10. OnePlus 6 Teardown: Schritt 10, Bild 1 von 2 OnePlus 6 Teardown: Schritt 10, Bild 2 von 2
  11. OnePlus 6 Teardown: Schritt 11, Bild 1 von 3 OnePlus 6 Teardown: Schritt 11, Bild 2 von 3 OnePlus 6 Teardown: Schritt 11, Bild 3 von 3
    • Before we leave the board, let's talk waterproofing. We found some! There are black silicone seals surrounding all these flex cable sockets—as we found previously on the OnePlus 5, and just like on every iPhone since the 6s.
    • Moving down to the other end, under the single loudspeaker assembly, we find more gaskets surrounding the speaker grille, USB Type-C port, and nicely modular headphone jack.
    • Nice to see OnePlus go for gaskets over goo, making disassembly and reassembly a snap. We probably wouldn't jump into the pool with it, but it's nice to have a little protection that doesn't impede repair.
    That’s funny. I decided to give the pool jumping a try, OP6 in my pocket for about 1 minute. Screen died :(
    Daniel Hoffpauir - Antwort
  12. OnePlus 6 Teardown: Schritt 12, Bild 1 von 3 OnePlus 6 Teardown: Schritt 12, Bild 2 von 3 OnePlus 6 Teardown: Schritt 12, Bild 3 von 3
    • Let's circle back and talk cameras for a moment.
    • Although a dual rear-camera setup first emerged on the OnePlus 5, this OnePlus includes OIS—a feature we haven't seen since the OnePlus 3T. Coupled with the brand-new IMX519 sensor from Sony, this seems like a significant step up, although early reviews have been surprisingly ... mixed.
    • Alongside it resides the 20 MP Sony IMX 376K sensor, returning from the earlier OnePlus 5T. The selfie cam gets the 16 MP IMX 371, which has been in circulation since the OnePlus 5 days.
    • Returning to the bottom edge, we flip out this little daughterboard and survey what's left in the chassis.
    • That OLED panel is firmly glued in place—it probably won't come out undamaged. You'll likely only be removing a broken display of course, but the procedure for doing so sure isn't repair-friendly.
    Slightly incorrect as this isn't the first OnePlus to have OIS. The OnePlus 3 and 3T had it as well.
    labib77 - Antwort
    Thanks for the correction, I updated the step to reflect that.
    Adam O'Camb -
    I’m surprised how you go on to make a universal claim about the camera saying “reviews have found it to be lackluster versus the competition”, with the “review” from theverge as your only source, when this definitely isn’t the general consensus across the review-sphere.
    Marios Taki - Antwort
    @mtaki14 Fair point! Amended to say early reviews have been mixed, with links to several reviewers who feel the OnePlus 6 camera compares favorably with the Pixel 2 and iPhone X.
    Jeff Suovanen -
    Please help me
    Need one plus 6 schematic diagram !
    MASUD LAB - Antwort
  13. OnePlus 6 Teardown: Schritt 13, Bild 1 von 1
    • That's a wrap! If we had one word to describe the sheer number of pieces we pulled from this phone, it would be twelve.
    • While we're on the subject of hard numbers, let's give this phone a repairability score.
    I having oneplus 6 8GB + 128GB variant and I need main mother board for it, my phone keep on restarting and the WiFi is not connecting.. any suggestions pls
    Sathish Kumaran - Antwort
  14. Fazit
    • The battery can be accessed almost the moment you open the phone, and is only lightly adhered in place. Plus, there's a convenient pull tab.
    • Many components are modular and can be individually replaced.
    • All the threaded fasteners are of the standard Phillips variety.
    • Display replacement, the most common repair, is not prioritized in the design and will take a lot of work.
    • Front and back glass means twice the risk of cracks—without even the benefit of wireless charging.
    • The primary access point for all repairs is heavily glued in place.
    Reparierbarkeits-Index
    5
    Reparierbarkeit 5 von 10
    (10 ist am einfachsten zu reparieren)
Adam O'Camb
196.194 Reputation
416 Anleitungen geschrieben
20 Kommentare
I can’t fully grasp what that huge plunger is doing, even with your description and images. I’m 100% confused
Dave Davidson - Antwort
I’d guess it’s there for better alignment. The detent on the 3T that I have works well, but there is some play introduced because the slider can roll slightly on the head of the switch, giving it some slop.
sawyer bergeron -
Is the vibrator a linear system or a rotating one? I remember seeing a casing similar to this one on the S6 and S7 (which gave strong, quiet vibration) but it could just be a circular rotating assembly like on the original Nexus 5 (which was honestly horrible.) I’m hoping it’s the former, as that would be a significant upgrade over the standard barrel motor vibrator on previous Oneplus phones.
sawyer bergeron - Antwort
The vibrating motor looks like a rotating one from the pictures above (Step 11 picture).
Chetan Gole -
So there is no heat sink or heat pipe here as we see these days with those Samsung flagships!
Jidhin George - Antwort
I want to know how can we put back the back glass with adhesive
divyamparmar - Antwort
It’s will be a little difficult for this since it bonded with a very high force adhesive.
Qing Liu -
Thanks for video ) I'm interesting, Oneplus 6 mirror/midnight models have the same as color and material frames (not battery cover) or not?
Nika Vasadze - Antwort
I find it strange that they tell you the battery is not removable, I mean literally it is, it isn’t soldered lol.
Alec - Antwort
Hi i have a oneplus 6, i bought when its release, after that phon droped in swiming pool now i can’t see anything on screen but still i am getting calls and vibrate ring tune all working fine but can’t see anything on screen, can someone help me with this situation.
sagar - Antwort
Your display is gone. Now you have two possibilities: You can get a display from an online store and do it yourself, or you can send your phone to OnePlus, the replacements are actually not as expensive as in case of Samsung and Apple for example.
Nils Kaper -
The chances are that OnePlus will deny to repair your phone though. By repairing your phone they have to guarantee the working of the replaced part, which in case of water damage is really unpredictable. After water damage every device could die any minute, technically. Most brands refuse to replace anything on water damaged devices.
hellcometo -
Trying to fix my girlfriend's phone for her birthday - which is tomorrow!
Replaced the screen on the OnePlus six - was very careful so thought I'd done a good job. When I plug the phone in it vibrates and responds to pushes of the power and volume buttons, but I see nothing on the screen. What do I do?
Sam A - Antwort
Check the connection cables. Probably either the cable plug on the screen or on the Mobo are damaged. If that doesn't work send it to OP. As long as it hasn't got water damage they will repair it
Helyx -
I am curious to know how waterproof is the device. Any improvements over the 6?
Josue Reyes - Antwort
Can i replace Volume button?
Алексей Бурдасов - Antwort
I dropped my oneplus 6 in the water and screen wasn’t going on so i bought a replacement and fixed it my self and now the screen works again :) Now my 2nd problem is that i dont have any sound from the bottom speaker and i bought a replacement but no luck so i guess its tied to something on the motherboard? Call speaker and headphone jack still works so i have no clue on what to do next and hope someone on here can help me?!?
Mc JinX - Antwort
Can you please provide a teardown wallpaper? It will be greatly appreciated.
Nii Noi - Antwort
I snapped the connector of the white cable connected to the motherboard. Does anyone know what it does?
Aidan Chui - Antwort
io nell'aprire la cover ho strappato quel piccolo cavetto bianco che corre lungo tutto il telefono, a che cosa serve?????
lo steccone - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 66
Letzte 30 Tage: 310
Insgesamt: 130,646
