The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
Many components are modular and can be individually replaced.
Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
The primary access point for all repairs, the rear panel, is firmly glued in place.
6 Kommentare zur Anleitung
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Antwort Teilen
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge - Antwort Teilen
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Antwort Teilen
OnePlus 7 pro 8/256
Anita Jajoriya - Antwort Teilen
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Antwort Teilen
