Was du brauchst
Einführungsvideo
- The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
- Many components are modular and can be individually replaced.
- Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
- While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
- The primary access point for all repairs, the rear panel, is firmly glued in place.
Fazit
Reparierbarkeits-Index
4
Reparierbarkeit 4 von 10
(10 ist am einfachsten zu reparieren)
6 Kommentare
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Antwort
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Antwort
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Antwort
Where the sensor board is located, my gyro doesn't work, even though I change direction my phone maps doesn't align
Vivekanand P - Antwort
