Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein PSP 1000 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. PSP 1000 Teardown, PSP 1000 Teardown: Schritt 1, Bild 1 von 3 PSP 1000 Teardown, PSP 1000 Teardown: Schritt 1, Bild 2 von 3 PSP 1000 Teardown, PSP 1000 Teardown: Schritt 1, Bild 3 von 3
    • This is the easy part, place the PSP upside down, on its top side.
    • There's only one screw to take out here. Since I'm no genius when it comes to screw sizes, I'll let you pick the right one from your set of twenty.
    • Remove the battery cover.
  2. PSP 1000 Teardown: Schritt 2, Bild 1 von 3 PSP 1000 Teardown: Schritt 2, Bild 2 von 3 PSP 1000 Teardown: Schritt 2, Bild 3 von 3
    • Start by removing the three screws highlighted by the red circles.
    • Take care when removing the forth screw, as it's slightly tighter than the rest. This screw is highlighted in blue.
    • This is the point of no return, if you choose go on, you're voiding your warranty. So, carefully peel back the warning sticker all the way off.
    • You'll find two small screws concealed below the label, remove those screws.
  3. PSP 1000 Teardown: Schritt 3, Bild 1 von 3 PSP 1000 Teardown: Schritt 3, Bild 2 von 3 PSP 1000 Teardown: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    Kaufen
    • You can now start to carefully pry the top cover from the unit, using the spudger. Start from right to left, leveraging slowly.
    • Contrary to what this picture might suggest, this PSP hasn't contracted chickenpox. Each red circle indicates a screw that you need to remove.
    • Carefully unclip the connector circled in red.
  4. PSP 1000 Teardown: Schritt 4, Bild 1 von 3 PSP 1000 Teardown: Schritt 4, Bild 2 von 3 PSP 1000 Teardown: Schritt 4, Bild 3 von 3
    • Open the UMD slot. With the screen facing towards you, unclip the locks at the bottom right outer-side of the hinge, and the bottom left, inner-side of the hinge. Remove this component.
    • Remove the four newly revealed screws, in any order. If you're afraid of commitment, you might like to assign each screw a number between 1-4, and decide using a random number generator. Remove this component.
    • Place the PSP face up, with the joystick side on the right. There are two lock clips located on the right side of the LCD, unhinge these. Remove this component.
  5. PSP 1000 Teardown: Schritt 5, Bild 1 von 3 PSP 1000 Teardown: Schritt 5, Bild 2 von 3 PSP 1000 Teardown: Schritt 5, Bild 3 von 3
    • Now don't get all gung-ho, be careful when detaching the LCD, as it's attached with two connectors. You can unlock these connectors by pulling back the brown latches VERY carefully.
    • Same deal again, go crazy with remove the screws highlighted in red... Crazy in a calm and collected way. Remove this component.
    • Disconnect these two cables.
  6. PSP 1000 Teardown: Schritt 6, Bild 1 von 3 PSP 1000 Teardown: Schritt 6, Bild 2 von 3 PSP 1000 Teardown: Schritt 6, Bild 3 von 3
    • Remove the screw labelled in red (to the top right of the device, the other is incorrectly labeled in the image). These are holding down the main circuit board.
    • Almost there, if you've come this far, I commend you on your effort! Again, carefully pry open the cable lock and remove the WiFi component.
    • Remove the circuit board, this might be the most important step. Sit back and gaze at the chips for at least 5-8 minutes. NOTE: You can come back to this step at any point.
  7. PSP 1000 Teardown: Schritt 7, Bild 1 von 3 PSP 1000 Teardown: Schritt 7, Bild 2 von 3 PSP 1000 Teardown: Schritt 7, Bild 3 von 3
    • You can now remove the WiFi board and chip, along with the metal plate.
    • The chip Sony used in the original PSP could pick up wireless G bands, which made it a nippy handheld network device for its time.
    • At the time, £280 worth of circuitry, wires, metal and plastic. Beautiful sight.
  8. PSP 1000 Teardown: Schritt 8, Bild 1 von 3 PSP 1000 Teardown: Schritt 8, Bild 2 von 3 PSP 1000 Teardown: Schritt 8, Bild 3 von 3
    • You're all done, this step is just to bring the steps in this teardown to an even number :)
    • Mmm... circuits. SIDE NOTE: I'm not certain, but I think that the chips circled in red control the DRM for the device ;)
    • P.s. Apologies for the relatively low-res images, but it's the best my camera could muster.
  9. PSP 1000 Teardown: Schritt 9, Bild 1 von 1
    • By request, I've also included the component overview as its own step in the process.
Armin Talic
520 Reputation
1 Anleitung geschrieben
9 Kommentare
What about repairability score
fghjsfj - Antwort
Written by ifixit = repairability score
not Made By ifixit = no repairility score
Lucas Hoekstra (Lucas9810) -
So I just did this and I love the result. I actually had a PSP-3001 so the step with the clips was confusing but I figured it out! I can't believe I took apart a PSP worth $411! It was so funnnn
Amelia Witt - Antwort
Leonardo Jovani v. lazer it working as I press down what makes it light up n just got my gran tursimo working but it blackscreen again should I return n get used again frm same seller or repair with sony? email me gioo239@gmail.com or text me 239-203-8318
Leonardo Jovani Vazquez - Antwort
Hi, I replaced the case on my psp1000. When I put the thing back together I found the power switch doesn’t spring back like it used to. So if I turn the PSP on I have to physically push the switch back into the middle position otherwise it turns off again. Is there some sort of spring mechanism that I’ve missed? I have replaced the plastic switch and the yellow tab that it clips into. How does the spring mechanism work exactly? Hope this makes sense. Thanks!
Mike Fong - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 38
Letzte 7 Tage: 245
Letzte 30 Tage: 1,130
Insgesamt: 128,206
