Einleitung
Follow this guide to completely disassemble your Palm IIIc.
Was du brauchst
Keep track of all pieces removed from the device.
Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
Using a spudger, carefully pry open the front and back covers along the side seam.
Unhook battery cable from the motherboard and remove the battery.
Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
