Einleitung
In this tutorial we will show you a breakdown of the Panazonic EB TX320. By using this guide, a user will be able to properly take apart their phone and replace any broken components.
Was du brauchst
To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
