Was du brauchst
Clean the device. You are able to rinse with under running water. It is recommended to ensure that you remove the battery and memory card before working with the device.
Prepare a clean workstation and have your tool(s) ready.
Remove 4 Phillips 1/4 inch 00 screws around the border of the display with the screwdriver.
Remove the black rubber adhesive around the border of the device by peeling slowly.
Remove the display screen from the casing. When opening, the micro USB cover and the battery cover will fall out with a pin.
Remove the lens from the camera carefully. It is the black block held inside the casing.
Remove 3 Phillips 00 screws from the camera's photo capture button.
After removing those screws, remove the plastic piece and buttons they secure.
Remove 3 Phillips 00 screws from the same location located under the cameras photo capture button.
