Einleitung
The picture quallity is pretty bad, but i've done my best to make this teardown as comprehensive as possible. No parts description and macro shots here for now.
Was du brauchst
We'll begin with a few pictures of how the phone looks
Here we have the front, back and side views
The battery cover comes out quite easily, just press on the symbol on the lower side of the phone and pull it down
The battery itself, however, has a weird mechanism that must be first pulled up by the side (as shown in the first picture) and then, when the switch is in the possition shown in the second picture, pulled out by the plastic side.
This is also ilustrated on the battery itself.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
There are 8 clips(3 on each side and two on the top) holding the front case to the body (shown in picture 1 and 3). Oh, by the way, Philips didn't use any screws on this device, so don't worry about that.
A plastic card or pr plastic spudger is used to unclip the case from the body, starting on one side, from bottom to top, and then continuing on the other side in the same fashon. (picture 1)
The Keyboard membrane can be seen now. Also notice that the keyboard itself can be unattached from the front cover. The keyboard is made of silicone and can break easily, so be careful with it.
The back part of the phone is attatched to the board and lcd by 8 clips on each side (pic 1 ilustrates the biggest one) and two clips on the top (pic 3)
Removing it consists in pulling from the sides on the phone (from the point shown in pic 1) and pushing from the battery slot onto the motherboard
The body should be off, exposing the motherboard
Notice the metal shield, covering the motherboard from the 4 pins on the other side (pic 3).
Take out the shield from the motherboard by unclipping the 4 pins on the side (picture 3)
Now with the shield off, we can take off the screen.
The screen is held in place by two pins on each side (shown in pics 2 and 3).
To remove the screen from the board, take note that it comes off via a slide mechanism. Gently pull on the two sides and pull the board down on the slide. Once it stops, the screen should come down easily.
The display itself may look like it's glued to the grey body, but it comes right out when you flip it.
That's basically as far as i go, as i don't want to take off the second shielding soldiered on the board.
Ein Kommentar
I didn't use this guide for this device but for another phone of Philips, the CD180. I have zero experience with teardown of devices and thanks to this article I was able to teardown the phone. Thanks!
