Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
Before disassembling, unplug the Camera from the PS4.
Dieser Teardown ist keine Reparaturanleitung. Um dein PlayStation Camera zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. There are two PH0 Screws in the socket which hold the cable. Unscrew two PH0 Screws and pull off the cable holder. Unscrew two PH0 Screws and pull off the cable holder.
    • There are two PH0 Screws in the socket which hold the cable.
    • Unscrew two PH0 Screws and pull off the cable holder.
  2. The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious. The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious. The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
    • The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
  3. There is one more PH0  screw to remove. This one is behind the other lens.
    • There is one more PH0 screw to remove. This one is behind the other lens.
    • This was the easy part.
  4. There are many clips in there. There are many clips in there. There are many clips in there.
    • There are many clips in there.
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Encore two photos where to locate these nasty clips Encore two photos where to locate these nasty clips
    • Encore two photos where to locate these nasty clips
  7. The other half of the housing is attached to a solid U-Frame with the electronics. There are four silver screws, PH0. Four microphones, two with black/yellow cables and two with black/red wiring.
    • The other half of the housing is attached to a solid U-Frame with the electronics.
    • There are four silver screws, PH0.
    • Four microphones, two with black/yellow cables and two with black/red wiring.
  8. The backside of the U-frame. The cable is not soldered, there is a plug. Detail of the plug.
    • The backside of the U-frame. The cable is not soldered, there is a plug.
    • Detail of the plug.
  9. 6 PH1 screws. Take a small magnet to hold them. 6 PH1 screws. Take a small magnet to hold them.
    • 6 PH1 screws. Take a small magnet to hold them.
  10. The connector of the mikrophone-array The connector of the mikrophone-array
    • The connector of the mikrophone-array
  11. The lenses, plastic, glued tight. NOT ADJUSTABLE. NOT ADJUSTABLE.
    • The lenses, plastic, glued tight.
    • NOT ADJUSTABLE.
  12. Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it. I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
    • Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it.
    • I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
  13. Extra: The wiring.
    • Extra: The wiring.
    • It's an USB3 cable without green/white Pimf. There are three SEPARATE ISOLATED metalfoil shields with wire, red-black-power and two Pimf yellow/blue and orange/green. So ja, thats it. Paulaner.
Schwarzstein
2.445 Reputation
14 Anleitungen geschrieben
Only 7 steps? Where is the rest of the teardown? I wanted to see detailed images of the optics.
Alexandru Voda - Antwort
Ja, okay, i made some pictures for you. The optics are in Step 10.
Enjoy.
Freundliche Grüsse. :)
Schwarzstein - Antwort
Does anyone think it would be possible to cut the wires from two cameras and splice the wires together and put the power on a A/B rocker switch to switch between two cameras?
Dan Schultz - Antwort
Great job, congrats. Do you have also for the other version of ps4 camera same as this one? BR.
Cosmin - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 9
Letzten 30 Tage: 72
Insgesamt: 8,966
