Einleitung
Before disassembling, unplug the Camera from the PS4.
Was du brauchst
There are two PH0 Screws in the socket which hold the cable.
Unscrew two PH0 Screws and pull off the cable holder.
The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
There is one more PH0 screw to remove. This one is behind the other lens.
This was the easy part.
The other half of the housing is attached to a solid U-Frame with the electronics.
There are four silver screws, PH0.
Four microphones, two with black/yellow cables and two with black/red wiring.
The backside of the U-frame. The cable is not soldered, there is a plug.
Detail of the plug.
Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it.
I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
Extra: The wiring.
It's an USB3 cable without green/white Pimf. There are three SEPARATE ISOLATED metalfoil shields with wire, red-black-power and two Pimf yellow/blue and orange/green. So ja, thats it. Paulaner.
7 Kommentare
Only 7 steps? Where is the rest of the teardown? I wanted to see detailed images of the optics.
Ja, okay, i made some pictures for you. The optics are in Step 10.
Enjoy.
Freundliche Grüsse. :)
Does anyone think it would be possible to cut the wires from two cameras and splice the wires together and put the power on a A/B rocker switch to switch between two cameras?
What's the name of this USB cable? I need to replace mine…
