Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Pocket C.H.I.P. zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Pocket C.H.I.P. Teardown, Remove the CHIP: Schritt 1, Bild 1 von 2 Pocket C.H.I.P. Teardown, Remove the CHIP: Schritt 1, Bild 2 von 2
    • To start off, power off the computer, remove the CHIP on the back.
    • You shouldn't need any special tools for this, but it might be a little tight, so you might need to wiggle it a bit.
    • Be careful and apply even pressure so you don't bend the pins.
    Frag FixBot
  2. Pocket C.H.I.P. Teardown, Screen Cover: Schritt 2, Bild 1 von 1
    • Then remove the front screen border.
    • There are four clips around either side for you to unclip.
    Frag FixBot
  3. Pocket C.H.I.P. Teardown, Yummy Chips: Schritt 3, Bild 1 von 2 Pocket C.H.I.P. Teardown, Yummy Chips: Schritt 3, Bild 2 von 2
    • This is the main CHIP computer.
    • To access the rest of the computer, you need to remove the cover with a single Philips screw.
    Frag FixBot
  4. Pocket C.H.I.P. Teardown, Remove the back: Schritt 4, Bild 1 von 3 Pocket C.H.I.P. Teardown, Remove the back: Schritt 4, Bild 2 von 3 Pocket C.H.I.P. Teardown, Remove the back: Schritt 4, Bild 3 von 3
    • Remove the clear back cover
    • There are four clips, two on the top, two on the bottom that should be unclipped to remove it.
    Frag FixBot
  5. Pocket C.H.I.P. Teardown, Remove the battery: Schritt 5, Bild 1 von 3 Pocket C.H.I.P. Teardown, Remove the battery: Schritt 5, Bild 2 von 3 Pocket C.H.I.P. Teardown, Remove the battery: Schritt 5, Bild 3 von 3
    • Next, we need to remove the LiPo battery.
    • First, we need to unplug it from the CHIP. Simply pull it from the connector.
    • There is some adhesive holding the battery to the main board. I found twisting it while pulling worked wonders.
    • Be careful not to puncture the battery and follow proper battery-handling precautions.
    Frag FixBot
  6. Pocket C.H.I.P. Teardown, Unplug the screen: Schritt 6, Bild 1 von 2 Pocket C.H.I.P. Teardown, Unplug the screen: Schritt 6, Bild 2 von 2
    • The screen connector was hidden by the battery. Now that it's revealed, we can do our thing.
    • Pull the black bar up on both sides. It should come out completely.
    • You can now pull the ribbon cable up.
    Frag FixBot
  7. Pocket C.H.I.P. Teardown, Removing the screen: Schritt 7, Bild 1 von 3 Pocket C.H.I.P. Teardown, Removing the screen: Schritt 7, Bild 2 von 3 Pocket C.H.I.P. Teardown, Removing the screen: Schritt 7, Bild 3 von 3
    • There is some adhesive behind the screen. I put a card behind it and kind of sawed it off to remove it.
    Frag FixBot
  8. Pocket C.H.I.P. Teardown, The finale: Schritt 8, Bild 1 von 1
    • That's it, we've taken apart the Pocket chip! The only pieces are
    • The main board with the keyboard
    • The main CHIP computer
    • The LiPo battery
    • The screen
    • And the back case.
    Frag FixBot
askaye
182 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 65
Insgesamt: 943
