Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Table Lamp zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: Schritt 1, Bild 1 von 1
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: Schritt 2, Bild 1 von 1
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: Schritt 3, Bild 1 von 2 Portable Luminaries Lamp Teardown: Schritt 3, Bild 2 von 2
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: Schritt 4, Bild 1 von 2 Portable Luminaries Lamp Teardown: Schritt 4, Bild 2 von 2
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: Schritt 5, Bild 1 von 2 Portable Luminaries Lamp Teardown: Schritt 5, Bild 2 von 2
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: Schritt 6, Bild 1 von 2 Portable Luminaries Lamp Teardown: Schritt 6, Bild 2 von 2
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: Schritt 7, Bild 1 von 1
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
Brenden
56 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 1,725
