Was du brauchst
6 Kommentare
What’s the part number for the LCD screen? Do you know if it’s commonly found elsewhere?
The piece that has the mic came off mine when it fell i can see where it goes i just need to know how to connect it back so the mic will work plz help
How to start opening?
Do you have pics from the power supply?
Second the request on how to open the device. I need to solder the power switch back on the board and can’t figure out how to open the Portal Plus. Thanks.
I can’t quite remember where I started to open.. It was either the bottom or back of the device. This device was so difficult just to get the housing off, I had a really hard time, and at some point I just started to cutting. I have been taking things apart and reassembling ALL MY LIFE..I am good at it…SO GOOD LUCK with getting it open without damaging.
