Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Pyrex Professional Kitchen Timer and Thermometer zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Pyrex Professional Kitchen Timer and Thermometer Teardown, Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 1, Bild 1 von 3 Pyrex Professional Kitchen Timer and Thermometer Teardown, Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 1, Bild 2 von 3 Pyrex Professional Kitchen Timer and Thermometer Teardown, Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 1, Bild 3 von 3
    • Disconnect the temperature probe and turn the device off
    • Turn the unit over and remove the battery.
    • Remove the 4 screws from the bottom of the device.
  2. Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 2, Bild 1 von 2 Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 2, Bild 2 von 2
    • Carefully pull the back off. Keep an eye out for the C/F switch that is held in place by the bottom cover. Don't pull too hard or you may break the wires from the battery compartment.
    • Set the plastic C/F switch in a safe place as it bounces away easy and is small.
    • If you need to completely separate the cover from the case you will need to unsolder the wires to the battery compartment.
    • To reassemble, put the C/F switch in its spot and press the cover back on being careful not to pinch wires. Reinstall the 4 screws.
  3. Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 3, Bild 1 von 3 Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 3, Bild 2 von 3 Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 3, Bild 3 von 3
    • To dissemble the back, remove the 4 #1 Philips screws.
    • Carefully pry the back off being careful not to pull on the transducer wires.
    • You now have access to the display board and the transducer.
    • To reassemble, place the back on being careful not to pinch wires and reinstall the 4 screws.
rickwag
1.266 Reputation
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 47
Insgesamt: 75
