Einleitung
This is my tear down of the Razer Blade 14. I haven't yet seen anyone dismantle this notebook so i decided to give it as try and went as far as I felt comfortable going.
Was du brauchst
Remove the 10 Screws holding the back Cover on to reveal the mainboard.
DDR3 Ram chips
CPU Chipset
Liteon 256gb SSD (factory installed)
Factory WLAN/BT card
Battery
Aftermarket MSata SSD (installation screw not included)
Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
43 Kommentare
Is that a second mSATA slot I see on the left side of the motherboard underneath the large ribbon cable?
Indeed it is! it functions too, the stock is beneath the cable, the unpopulated is the exposed one, that i had installed an Mushkin atlas in and started using without a hitch.
tallme15 -
