Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Retro-Bit LegacyGC Wired Controller zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Retro-Bit LegacyGC Wired Controller Teardown, Remove the screws: Schritt 1, Bild 1 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the screws: Schritt 1, Bild 2 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the screws: Schritt 1, Bild 3 von 3
    • On the back of the controller, there are four visible screw posts around the controller. Use a PH00 Philips head screw bit to remove the screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Retro-Bit LegacyGC Wired Controller Teardown, Find and remove the hidden screw: Schritt 2, Bild 1 von 2 Retro-Bit LegacyGC Wired Controller Teardown, Find and remove the hidden screw: Schritt 2, Bild 2 von 2
    • A brand new controller likely has an inspection sticker on the bottom of the back of the controller.
    • This sticker is covering a fifth hidden screw. Use a sharp object to peel off the sticker, then use the PH00 screw bit to remove the last fifth screw.
    Frag FixBot
  3. Retro-Bit LegacyGC Wired Controller Teardown, Remove the ZL/ZR buttons: Schritt 3, Bild 1 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the ZL/ZR buttons: Schritt 3, Bild 2 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the ZL/ZR buttons: Schritt 3, Bild 3 von 3
    • After removing the screws, the back shell piece can be removed from the controller.
    • Be careful! The wire is attached to the printed circuit board inside a soldered connector. This cable cannot be removed. Do NOT pull on the cable too hard.
    • The ZL and ZR buttons are one piece. Simply grab one side and lift it out of the shell.
    Frag FixBot
  4. Retro-Bit LegacyGC Wired Controller Teardown, Remove L and R buttons.: Schritt 4, Bild 1 von 2 Retro-Bit LegacyGC Wired Controller Teardown, Remove L and R buttons.: Schritt 4, Bild 2 von 2
    • The L and R buttons are the next piece that can be removed. Simply grab them and lift them out of the shell.
    • The actual switch for the ZL/ZR buttons are soldered to the printed circuit board, while the L and R buttons are actuated by a membrane piece on their own daughter board, attached to the main board by a soldered ribbon cable.
    Frag FixBot
  5. Retro-Bit LegacyGC Wired Controller Teardown, Remove the L and R membranes.: Schritt 5, Bild 1 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the L and R membranes.: Schritt 5, Bild 2 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the L and R membranes.: Schritt 5, Bild 3 von 3
    • Lift up on the small, rectangular daughter board out of its grooves.
    • The membrane can then be removed from the controller.
    Frag FixBot
  6. Retro-Bit LegacyGC Wired Controller Teardown, Remove the printed circuit board.: Schritt 6, Bild 1 von 1
    • The printed circuit board can then be removed from the controller shell by hand.
    • The board, cable and L/R boards are all attached together.
    Frag FixBot
  7. Retro-Bit LegacyGC Wired Controller Teardown, Remove the turbo membranes.: Schritt 7, Bild 1 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the turbo membranes.: Schritt 7, Bild 2 von 3 Retro-Bit LegacyGC Wired Controller Teardown, Remove the turbo membranes.: Schritt 7, Bild 3 von 3
    • The front shell of the controller will have the front side buttons and its membranes.
    • In this disassembly, the A-B-X-Y membrane was stuck to the printed circuit board. It may instead rest over the buttons on the front piece.
    • Remove the turbo button's membrane by hand or tweezers.
    • Remove the clear button's membrane similarly.
    Frag FixBot
  8. Retro-Bit LegacyGC Wired Controller Teardown, Remove front button membranes: Schritt 8, Bild 1 von 2 Retro-Bit LegacyGC Wired Controller Teardown, Remove front button membranes: Schritt 8, Bild 2 von 2
    • Remove the Start/Select membrane by hand or tweezers.
    • Remove the D-Pad membrane similarly.
    • If the A-B-X-Y buttons are covered by a membrane, that may also be removed at this time.
    Frag FixBot
  9. Retro-Bit LegacyGC Wired Controller Teardown, Remove A-B-X-Y, Turbo buttons & D-Pad: Schritt 9, Bild 1 von 2 Retro-Bit LegacyGC Wired Controller Teardown, Remove A-B-X-Y, Turbo buttons & D-Pad: Schritt 9, Bild 2 von 2
    • The last remaining pieces are the A, B, X and Y buttons, the Turbo button, the Clear button and the D-Pad.
    • Remove each piece by hand or tweezers.
    • Alternatively, place a flat palm over the front shell, then use your other hand to turn the shell over. The pieces will fall onto the flat palm for a quick button removal.
    Frag FixBot
  10. Retro-Bit LegacyGC Wired Controller Teardown, Printed Circuit Board: Schritt 10, Bild 1 von 2 Retro-Bit LegacyGC Wired Controller Teardown, Printed Circuit Board: Schritt 10, Bild 2 von 2
    • The square chip on the middle left of the printed circuit board reads: 2322 36100.1
    • Interestingly, the board labels the select button (on the bottom-middle-left) as the Y button.
    Frag FixBot
Damian
1.530 Reputation
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 260
