Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Roborock Dyad Pro Combo zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the display: Schritt 1, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the display: Schritt 1, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the display: Schritt 1, Bild 3 von 3
    • Start by grabbing the display and twisting it counter clockwise.
    • This may require a lot or a little bit of force. Eventually it will give and at that point you can lift it up.
    • Once removing the display, remove the cable connecting it.
  2. Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the motherboard: Schritt 2, Bild 1 von 2 Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the motherboard: Schritt 2, Bild 2 von 2
    • Remove all the cables from the motherboard.
    • Then remove the 2 screws and take the motherboard out.
    • Use this as a reference during reassembly or take a better picture yourself.
  3. Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the battery: Schritt 3, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the battery: Schritt 3, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Removing the battery: Schritt 3, Bild 3 von 3
    • Remove the plastic housing.
    • Remove the battery. (It is not held in place by anything. Just pull it out.)
  4. Roborock Dyad Pro Combo: Fan Unit Teardown, Keep an eye on your feline assistant.: Schritt 4, Bild 1 von 1
    • She is always watching.
  5. Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.1: Schritt 5, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.1: Schritt 5, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.1: Schritt 5, Bild 3 von 3
    • Remove the screw from the inside.
    • Use your hand to force a small gap between the handle and the housing.
    • Fit blunt-tipped tweezers or a small flat head screwdriver into the gap.
  6. Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.2: Schritt 6, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.2: Schritt 6, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.2: Schritt 6, Bild 3 von 3
    • Push it upwards, until it won't re-seat by itself.
    • Push the cable as far into the handle as it will go to prevent damaging it once you get the handle apart.
    • If you do happen to pull a cable from the connector, the last image is a reference to how it's meant to be assembled. Try to reassemble it if you pull a cable out.
  7. Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.3: Schritt 7, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.3: Schritt 7, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Handle pt.3: Schritt 7, Bild 3 von 3
    • Remove the handle by defeating the latches using a Plastic card or iFixit's Jimmy.
    • Remove the screws, then remove the black plastic retainer.
    • Remove the grey lever by pulling it off. It is latched onto the main assembly.
  8. Roborock Dyad Pro Combo: Fan Unit Teardown, Connector PCBA assembly pt.1: Schritt 8, Bild 1 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Connector PCBA assembly pt.1: Schritt 8, Bild 2 von 3 Roborock Dyad Pro Combo: Fan Unit Teardown, Connector PCBA assembly pt.1: Schritt 8, Bild 3 von 3
    • Back inside, remove the 2 screws by the bunch of cables.
    • Move to the outside and force a gap between the main housing and the electrical contacts housing.
    • Use a plastic card to get the rest of the latches to unlatch.
  9. Roborock Dyad Pro Combo: Fan Unit Teardown, Connector PCBA assembly pt.2: Schritt 9, Bild 1 von 2 Roborock Dyad Pro Combo: Fan Unit Teardown, Connector PCBA assembly pt.2: Schritt 9, Bild 2 von 2
    • Remove the PCBA and the cable leading from the bottom.
    • Back inside, remove the 4 screws and the black foam on the bottom.
  10. Roborock Dyad Pro Combo: Fan Unit Teardown, Finish!: Schritt 10, Bild 1 von 2 Roborock Dyad Pro Combo: Fan Unit Teardown, Finish!: Schritt 10, Bild 2 von 2
    • And finally, take it apart.
DegenFixer
5.301 Reputation
24 Anleitungen geschrieben
2 Kommentare zur Anleitung
Thank you! Such a life saver.
Price Andrews - Antwort Teilen
Great teardown! Too bad that in my case, the source of foul smells turned to be the motor, which doesn't look like it can be disassembled non-destructively due to the duct being glued shut. Major design flaw in which moisture and/or dirty water can leak directly into the motor housing.
Also, in my opinion the motor access screws should be located on the bottom of the case, not inside covered up by everything else, requiring full teardown just to clean the business end.
M T - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 88
Letzte 30 Tage: 395
Insgesamt: 4,487
