Zum Hauptinhalt wechseln
Rowenta silent force extreme RO5931 main brush Teardown
Was du brauchst
  1. Rowenta silent force extreme RO5931 main brush Teardown, Unplug the vacuum cleaner: Schritt 1, Bild 1 von 1
    • Turn off the vacuum and unplug it from the outlet.
    • Unmount the main brush head from the cleaner pipe.
  2. Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: Schritt 2, Bild 1 von 3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: Schritt 2, Bild 2 von 3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top cover: Schritt 2, Bild 3 von 3
    • Unsnap the clips of the top cover with a small slot screwdriver.
    • Remove the top cover of the brush.
  3. Rowenta silent force extreme RO5931 main brush Teardown, Unscrew the two top Philips screws: Schritt 3, Bild 1 von 2 Rowenta silent force extreme RO5931 main brush Teardown, Unscrew the two top Philips screws: Schritt 3, Bild 2 von 2
    • Unscrew both Philips screws from the top of the brush.
  4. Rowenta silent force extreme RO5931 main brush Teardown, Unscrew security torx screws: Schritt 4, Bild 1 von 2 Rowenta silent force extreme RO5931 main brush Teardown, Unscrew security torx screws: Schritt 4, Bild 2 von 2
    • Unscrew both security torx screws.
  5. Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: Schritt 5, Bild 1 von 3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: Schritt 5, Bild 2 von 3 Rowenta silent force extreme RO5931 main brush Teardown, Remove the top of the brush head: Schritt 5, Bild 3 von 3
    • Smoothly and carefully take out the top of the brush head.
    • Take some time to search for the defect.
    • Remove broken pieces and repair if you can.
    • Clean up the inner parts of the brush with a smooth cloth. Remove dust, grains that could damage the inner parts of the brush.
  6. Rowenta silent force extreme RO5931 main brush Teardown, Check the handle of the brush retract is fixed: Schritt 6, Bild 1 von 2 Rowenta silent force extreme RO5931 main brush Teardown, Check the handle of the brush retract is fixed: Schritt 6, Bild 2 von 2
    • Push the retract button : the brush must be lowered.
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
David
1.580 Reputation
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
My vacuum is similar to the one shown here. Only had it a few months, now the suction is not very good, and is not picking up. The cylinder is not spinning around. Any advice. Thanks in advance
vivaespana - Antwort
I have a head the same and want to replace the joining hose and wish to know how to replace it as it has all holes in it and not sucking properly TIA
Toosje McWhirter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 2,231
