Was du brauchst
Einführungsvideo
- External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
- Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
- The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
- Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
- Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
Fazit
Reparierbarkeits-Index
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter-background.png)
![](https://assets.cdn.ifixit.com/static/images/repairability_meter/meter.png)
7
Reparierbarkeit 7 von 10
(10 ist am einfachsten zu reparieren)
7 Kommentare
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - Antwort
where can I find replacement parts?
Michel - Antwort
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - Antwort
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - Antwort
https://www.endrich.com/sixcms/media.php...
K T - Antwort
