Einleitung
This is a Teardown of my old broken Samsung Galaxy Pocket (GT-S5300)
Was du brauchst
Remove the battery cover
Then remove the battery
Slide a guitar pick between the sliver bezel and the rear of the phone
Slide it all the way around until the rear is loosened from the logic board and screen
Remove logic board from screen by lifting the logic board up and removing the digitizer connector
Slide guitar pick between the digitizer and lcd
Make sure not to get under the black adhesive on the back be the digitizer
