Einleitung
Taking a Samsung Galaxy S Blaze apart in case you need to fix it, is not hard.
Was du brauchst
The Samsung Galaxy S Blaze is a 121.9 x 63 x 11.2 mm (4.80 x 2.48 x 0.44 in) phone.
Weights 127.6 g (4.48 oz).
The resolution is 480 x 800 pixels (~235 ppi pixel density).
Released on March of 2012.
Use the Phillips size 00.
Remove the 8 4mm visible screws.
Then proceed to uncliping the back panel, starting from the top with the blue plastic opening tool.
Once you have taken the back panel you should be able to see the back of the motherboard.
The vibrator.
The 5 MP camera.
These are all the parts that will come from the phone if you decide to tear it down.
1 Kommentar zur Anleitung
where is the combo part ihave to purchase that is body of samsung gt1900
