Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung Galaxy S II zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: Schritt 1, Bild 1 von 3 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: Schritt 1, Bild 2 von 3 Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: Schritt 1, Bild 3 von 3
    • The 4.3-inch super Amoled Plus display is simply gorgeous!
    Frag FixBot
  2. Samsung Galaxy S II Teardown: Schritt 2, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 2, Bild 2 von 2
    • Look at how slim the phone is! Only 8.49mm thin!
    • Back cover is flexible but don't worry it will not break. It also has a nice texture to it.
    Frag FixBot
  3. Samsung Galaxy S II Teardown: Schritt 3, Bild 1 von 1
    • Look at how compact everything is inside!
    • Remove the seven visible screws.
    • Then unclip the back panel starting on the left next to the audio jack. Go slowly.
    Frag FixBot
  4. Samsung Galaxy S II Teardown: Schritt 4, Bild 1 von 3 Samsung Galaxy S II Teardown: Schritt 4, Bild 2 von 3 Samsung Galaxy S II Teardown: Schritt 4, Bild 3 von 3
    • Removing the back panel gives you an impressive and sophisticated view of the internals.
    Frag FixBot
  5. Samsung Galaxy S II Teardown: Schritt 5, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 5, Bild 2 von 2
    • Removing the motherboard is as simple as it looks !
    • Unclip the 5 ribbon connectors and the antenna cable.
    • Then remove the 2 small black screws.
    • Don't forget to unglue the volume flex and power flex, they are attached to the motherboard. Otherwise the motherboard won't come out easily like it should.
    Frag FixBot
  6. Samsung Galaxy S II Teardown: Schritt 6, Bild 1 von 3 Samsung Galaxy S II Teardown: Schritt 6, Bild 2 von 3 Samsung Galaxy S II Teardown: Schritt 6, Bild 3 von 3
    • The board with removed EMI shields.
    • The front.
    • ..and the back.
    • The front panel without the logic board.
    • The front facing camera part, the cinch-vibrator-1.mic part and the usb connection-2.mic-antenna board.
    Frag FixBot
  7. Samsung Galaxy S II Teardown: Schritt 7, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 7, Bild 2 von 2
    • The camera connector is at the upper left corner in the second picture.
    • The power and volume buttons are soldered to the logic board.
    • View the picture in HQ if you want to be impressed!
    Frag FixBot
  8. Samsung Galaxy S II Teardown: Schritt 8, Bild 1 von 1
    • This EMI shield is nearly a heat sink.
    • Should be useful with a 1.2GHz dual core under it!
    Frag FixBot
  9. Samsung Galaxy S II Teardown: Schritt 9, Bild 1 von 3 Samsung Galaxy S II Teardown: Schritt 9, Bild 2 von 3 Samsung Galaxy S II Teardown: Schritt 9, Bild 3 von 3
    • The (tiny) 8MP camera.
    • It's smaller than an iPhone 4 camera.
    Frag FixBot
  10. Samsung Galaxy S II Teardown: Schritt 10, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 10, Bild 2 von 2
    • The front-facing camera and the light sensor are a single part.
    • The front-facing camera is 2MP, which is better than the iPhone 4's VGA camera.
    Frag FixBot
  11. Samsung Galaxy S II Teardown: Schritt 11, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 11, Bild 2 von 2
    • The vibrator, first mic (did you know there are two?), cinch plug and the earspeaker.
    Frag FixBot
  12. Samsung Galaxy S II Teardown: Schritt 12, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 12, Bild 2 von 2
    • The USB-connection and 2 x mic board.
    • It's stuck with glue to the front panel.
    • The (only) antenna cable and a metal shield holding the light sensor in place.
    Frag FixBot
  13. Samsung Galaxy S II Teardown: Schritt 13, Bild 1 von 2 Samsung Galaxy S II Teardown: Schritt 13, Bild 2 von 2
    • This is it.
    • It still works after reassembly!
    Frag FixBot
lon
2.873 Reputation
2 Anleitungen geschrieben
20 Kommentare zur Anleitung
Why not show the great display? =\
Diego Sampaio - Antwort Teilen
Do you see the NFC module ? (the phone come frome England?)
Beacause there is a big disscution between ethier the NFC is not implemented on phone, maybe the chip is on ?
Forever TPC - Antwort Teilen
no, it should be from germany, I bought it there ;)
lon - Antwort Teilen
I'll change it for you ;)
Where can I purchase any mobile NFC chip and solder on to Galaxy S2 International version (I9100)?
Tai Li - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 140
Insgesamt: 567,064
